A-pillar Removal
A-pillar Removal
How do I remove the A-pillars? I was looking in the User Manual I downloaded from here and it says you need to undo some clips. I tried to pry it out with a screw driver, but it started to crack. How do you guys remove the A-pillars. I just need to get rid of those squeaks!
Aaron
Aaron
"Using a screw driver with a cloth at the tip,
pry off the trim from the top. It may take a bit of coaxing, but it will snap off." Pulled this out of the stickies. Here's the link: a-pillar mod Of course, this doesn't give much more info than you know, but it helps to know this is the course of actioin others have taken. Have fun.
I got the driver side A-pillar off easily. Then I put some felt tape around the bottom of it. That seemed to stop the creaks, I just had a little trouble placing it back in.
I NEED A PASSENGER SIDE A-PILLAR NOW!!!!!!!!!! THe whole thing cracked into 4 pieces while taking it out. Part of it was like stuck in the window caulking.
Anyone have a tan passenger side A-pillar?
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
