Whitch Pressure Plate
Old Jan 9, 2005 | 03:48 PM
mad-max98's Avatar
Which Pressure Plate
is it the 5.5 or 5th generation pressure plate and what else do you use in combination with that "bearings,clutch disc etc"
Old Jan 9, 2005 | 04:07 PM
Terran's Avatar
Pm Jsutter, but I believe it is 5th gen (2000-2001) because the aftermarket clutches are 1995-2001.
Old Jan 9, 2005 | 04:34 PM
mad-max98's Avatar
bump.......
Old Jan 9, 2005 | 05:38 PM
RA030726's Avatar
I'm nutty for Nissans
The 2000 PP is the one to go with. May as well get the 2000 disc to go along with it. The 01 is smaller I am told, so avoid that one.
The 3.5L pressure plate is a tiny bit larger and may not fit. Flywheel is probably different too, with posibly a different bolt pattern.
Anyhow stay 100% OEM if you are normally asperated.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
