Knock Sensor In
Old Jan 10, 2005 | 01:34 PM
mu_max's Avatar
Knock Sensor In
Installed the knock sensor, I feel a bit of a difference (seat of the pants acceleration is somewhat noticeable) but not as much as when I cleaned the throttle body, the IAC, replaced the fuel filter, and air filter. Hopefully gas mileage will improve too.
My hand is torn up, didnt realize it was that tight of a fit. You have to let go of the claustrophobic tendencies when in there. I was glad my hand came back out! I found it was easier to get a box end 12mm in there to loosen it up and replace. I felt I needed a bit more peace of mind so I took the extra time to get the socket, universal, extension, and ratchet on it to tighten it up. The original was throwing the code and the old sensor's casing was also cracked when I pulled it out.
Hopefully I wont need to do it again anytime soon, my hand looks like crap. Those razor blade like intake gaskets or whatever they are, sure are sharp.
My two cents, nothing more.
Old Jan 10, 2005 | 02:32 PM
Gramdacious's Avatar
I hear ya, I had my ultra skinny friend and his smallish hands get in there and do the hard work. 20 minutes later, I was melting my tires.
Old Jan 10, 2005 | 02:58 PM
97maxxx's Avatar
where do u guys get ya sensors? let me kno i need one just not looking to spend 100 for one
Old Jan 10, 2005 | 03:04 PM
BigLou93SE's Avatar
Look at jerryromenissan.com . He has knock sensors in the factory box for $114 shipped, and generically boxed ks's for $85 shipped. I bought the generic boxed ks, but haven't installed it yet.
Old Jan 10, 2005 | 04:36 PM
SlackR237's Avatar
Rollin' on 'Caps
Immediately after I installed my knock sensor, I didn't really notice a big improvement in my sluggish acceleration... After about a week or so I could feel all the power back again, it was kind of weird.
Most people feel the power right away, though, so maybe it varies.
Old Jan 10, 2005 | 04:53 PM
Jerry Rome Nissan is the best place to get knock sensors. I got mine for about $84 shipped.
Old Jan 10, 2005 | 05:09 PM
Dagger969's Avatar
Ive seen ones that are supposed to be oem on ebay for about 80-100 pretty regularly. Is this not such a good idea getting it from ebay?
Old Jan 10, 2005 | 08:04 PM
SlackR237's Avatar
Rollin' on 'Caps
I got mine from eBay, it works just fine...
Just make sure it's a genuine nissan part and it should work out well.
Old Jan 10, 2005 | 08:09 PM
ABK's Avatar
ABK
You need to reset your ECU if you don't want to wait a week for your computer to relearn the timing and fuel maps. If you reset it starts adapting right away.
Old Jan 11, 2005 | 08:11 AM
mu_max's Avatar
Ebay
I got my knock sensor offof Ebay form what appeared to be a private seller. It was $89 shipped. When it arrived it was an OEM piece. I reset the computer before starting the car up again. Like I said it does run a bit better and hopefully the mileage will be higher with the next fill up. I would have probably noticed more of a difference if I didnt clean the TB, IAC, and replace the filters a few days before.
Old Jan 11, 2005 | 08:25 AM
Dagger969's Avatar
Maybe Ill do that as well. My max has 119,xxx and I have put only 2,xxx on it. Dont really know how well its been maintained since its a repo. Ah well, its in good hands now.
Old Jan 11, 2005 | 11:06 AM
blkmaxz95's Avatar
Got mine at the dealership for 77 dollars.
Old Jan 11, 2005 | 02:21 PM
maximum810's Avatar
How are you able to replace the KS??? What tools are you using?
Old Jan 11, 2005 | 02:25 PM
NmexMAX's Avatar
dot dot dot ...
1/4 in ratchet with a 12mm socket, and a floor jack handle as a breaker bar.
Old Jan 11, 2005 | 02:46 PM
madmax96's Avatar
i used a3/8"ratchet with a 1/4"x 3/8" adabter to get more power on it and a 12mmswivel socket and a 18 " extension and some tape to tape the bolt to the socket i half no cuts on my hands this way took me about 20 min.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
