Tail lights went out(its not the fuse)
Old Jan 12, 2005 | 12:14 AM
Supermax95's Avatar
Well i went ahead and made my own red/clear tails and after doing so i noticed that neither of my tail lights were working. The signal lights, brake lights and reverse lights work fine, but the tails don't. I checked the fuse and it's not that. I changed both bulbs and it isn't that either...anyone have any suggestions??? Are there any relays that for the tail lights??
Thanks in advance.
Old Jan 12, 2005 | 06:47 AM
C MAX's Avatar
Thanks in advance.
change the 7.5 amp fuse in the engine compartment near the battery, that should solve your problem.
Old Jan 12, 2005 | 12:24 PM
Supermax95's Avatar
i tried, its not that or the 15 amp one, or the ones inside the cabin.
Old Jan 12, 2005 | 12:46 PM
ny96max's Avatar
re-check every fuse you have under the dash... sometimes fuses you would never think of could be what are blown. Also look under the hood and check those out as well.
Ant
NmexMAX's Avatar
dot dot dot ...
Check the harness.
Old Jan 12, 2005 | 12:48 PM
DAVE Sz's Avatar
Hooooooonda.....
The taillight fuse isn't the only one that could cause that. Check all of them. Once my blinkers went out so I replaced that fuse and they still didn't work cause the taillight fuse and the hazard fuse were both blown.
Old Jan 12, 2005 | 01:10 PM
C MAX's Avatar
just take your time its got to be one of them. i had the same problem i thought i changed all the fuses but i was wrong i missed one.
Old Jan 12, 2005 | 03:51 PM
Ant96GLE's Avatar
Brake light switch, I've gone through 3 of them already...
pktaske
May 6, 2016 07:49 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
