knock sensor???
failed inspection today on my 98
-y pipe + highflow cat + b pipe + stock muffler -car has 79000 miles -did the 60k tuneup Would the knock sensor have anything to do with it?? |
Come on now.
Help us help you. WHY did they tell you it failed????????????????????????????? |
Your from NY, they give you a print out and WHY you failed, it doesnt get easier than that.
RELAX PR*CK I dont have the print out, dropped the car off in the morning & didnt get the call till late so the car is still at the shop.
Originally Posted by mzmtg
Come on now.
Help us help you. WHY did they tell you it failed????????????????????????????? I recall him saying something about egr and nox |
EGR system is clogged or dirty, probably a CEL and NOx means you went over the limit on the dynometer...
so what has to be done and how much |
I dont know, find out exactly what was wrong... I'm only taking a guess by what you said.. Is your check engine light on? if so run the codes
no check engine light
Dude you were being the P*rick he was only trying to HELP you and simply needed more information to HELP you out. A failed inspection could mean a variety of things. Wait till tomorrow grab your printout and see what the mechanic says. Then if it seems too costly tell us what he said and we will give you advice...just chill out dude in the meantime
Got the results back:
HC 0.77 C0 9.32 N0x 2.13 - MAX HC 0.60 C0 10.00 N0x 1.50 - test limits mechanic said it was the cat (warpspeed metallic substrate cat) |
so can i assume warpspeed wasn't talking about ny when they said it would pass
© 2024 MH Sub I, LLC dba Internet Brands
