00vi
Old Jan 15, 2005 | 07:07 PM
HoLLaAtMyMaXx's Avatar
00vi
hey guys im thinkin about maybe doing the 00vi mod ......i have herd its alot of work and i dont know much about it......but i might be getting a hold of a 2000 max......can someone post the procedure in installing one or....any of the extras you need for it to bolt up ...i have heard you need a harness and maybe injectors is this true
any info is helpful
thanks
chuckie
Old Jan 15, 2005 | 07:11 PM
goodhead's Avatar
hey bro you will need:
1 upper IM
2 lower IM
3 fuel rail and injectors
4 injector harness for all 6 injesctors (3 are on a harness and other 3 needds to be cut off)
5 rear valve cover(not ness. but makes it easier)
6 some kind of adapter for the iacv to bolt on to and fit your throttle body of choice
7 a fuel fitting found herethanks to krismax)
Fuel Rail Off-fitting
http://www.sx7r.com/parts.htm
8 injector fuel hose **make sure you the injector kind not the regular kind**
9 and injector hose clamps**make sure you the injector kind not the regular kind**
10 jb weld to plug some of the vacum lines
11 good to replace the gaskets while your at it
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
