No Brake Lights....
Old Jan 16, 2005 | 08:58 PM
PLkiller's Avatar
No Brake Lights....
All of my brake lights do not work...I checked fuses and the bulbs...what gives? I noticed it when I was changing the bulb on the front driver's side marker lamp...Are the two connected in any way?
Old Jan 17, 2005 | 12:09 AM
dko683's Avatar
last week my tail lights and marker lamps both went out. i had to replace a fuse. it was in the interior fuse box, the fourth one from the bottom of the left column of fuses. i barely noticed that the fuse was broken. it would really help if you used a test light. i hope that helps.
Old Jan 17, 2005 | 07:54 AM
PLkiller's Avatar
I got no test light...The fourth fuse from the bottom on the left column is "A-T something"
Old Jan 17, 2005 | 11:48 AM
dko683's Avatar
yeah .. "A/T Cont" something like that. i have no idea what that is but that was the fuse that was burnt for me.
Old Jan 17, 2005 | 12:25 PM
|Bijan|'s Avatar
UCF Lexus
Do your headlights work? Its 99.9% likely a fuse
Old Jan 18, 2005 | 02:43 PM
PLkiller's Avatar
I checked the fuse (Stop Light) and its fine. I think I may need to take it to the dealer. Also, now my power lock button locks all doors but the driver's...what gives?
Old Jan 18, 2005 | 02:53 PM
Ant96GLE's Avatar
Brake light switch, mine went out on me like 3 times.
Old Jan 18, 2005 | 02:57 PM
PLkiller's Avatar
Where is it and how do I fix it?
Old Jan 18, 2005 | 04:58 PM
Ant96GLE's Avatar
The switch is located under the dash, follow the brake pedal and you will see a small peg that moves out whenever you press the brake pedal down... thats the switch. To take it off theres a nut where the peg is at and on the opposite side there is a plug. Its only like $8 at autozone
Old Jan 19, 2005 | 06:48 AM
PLkiller's Avatar
thanx...i will check it out today
Old Jan 19, 2005 | 10:55 AM
PLkiller's Avatar
Big thanx to Ant....It was the brake light switch. Replaced it in about 10 minutes. I would have never guessed it was that. I took a bunch of pictures, do I smell a write up?
Old Jan 19, 2005 | 02:38 PM
Ant96GLE's Avatar
Yer Welcome
I dont even think a write up is needed.. how easy was that?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
