UDP install: strap wrench?
Old Jan 17, 2005 | 08:15 AM
Powerman5115's Avatar
I'm getting my UDP this week. I'm not too woried about the install, but in the Hayne's manual it says to use a strap wrench on the pulley to hold it when getting the bolt off. Those who have installed one how did yall get the stock pulley off? Or could I probably rent one from Autozone or Napa?
Thanks,
Mooney
Old Jan 17, 2005 | 08:19 AM
mzmtg's Avatar
Minister of Silly Walks
Just put the car in gear. If you only jack up that side of the car, the other wheel on the ground will keep the motor from turning.
Old Jan 17, 2005 | 10:02 AM
I don't really trust jack stands when I'm under the car. What I was planning to do was to put the front wheels on ramps. Would I still have easy access to the pulley?
Mooney
Old Jan 17, 2005 | 10:08 AM
mzmtg's Avatar
Mooney
Not really. You need to have the right wheel off to get in there. I won't say it can't be done with the car on ramps, but it will be seriously difficult.
Old Jan 17, 2005 | 12:04 PM
PAREDLINE's Avatar
Taking the pulley off isnt hard to do. Unless you dont have an impact wrench.
If it's never been removed I can almost assure you that you'll have to heat the bolt before it comes off. Heat for like 2 mins with a propane or Mapp torch. Then impact the bolt off.
You might get lucky with hand tools. you might not. then you waste hours and get nowhere
Old Jan 17, 2005 | 12:14 PM
mzmtg's Avatar
To get the bolt off, disconnect the ignition coils, put the socket on a breaker bar, put the socket on the bolt with the end of the breaker bar on the ground pointing towards the front of the car, crank the starter.
The starter will have more than enough torque to break the bolt loose.
Old Jan 17, 2005 | 01:11 PM
ny96max's Avatar
thats pretty much how Jeff at Max Tuning did my UDP.
Ant
Old Jan 17, 2005 | 06:28 PM
jcy98maxse's Avatar
Turbo is too much fun!
I did that too, it works quite well.
Old Jan 17, 2005 | 06:34 PM
SamMan23's Avatar
Now how do you guys get the pulleys torqued on properly?
Old Jan 17, 2005 | 08:18 PM
Broaner's Avatar
2060lbs and falling...
I had no problem stoping its rotation with my hand. If you need a bit more friction tighten it down a bit and then put the belts on. Once the bolt is torqued you should re-tension the belts.
Hdnseek
Sep 9, 2015 05:55 AM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 12, 2015 01:54 AM
