Could U???
Old Apr 25, 2001 | 07:51 PM
WhteMax's Avatar
Put a 5th Generation maxima engine into a 4th Generation???
Old Apr 25, 2001 | 10:34 PM
buss95max's Avatar
i doubt it..i dont think it lines up right..i may be wrong
Old Apr 25, 2001 | 11:32 PM
emax02's Avatar
I think the mounts are the same so it should fit in no problem, you would definatly need a 2K max's ECU and wiring etc.. I suggest you look into it extensively before even thinking about doing it. If you do the swap make sure to let us all now. Good luck!
Old Apr 25, 2001 | 11:41 PM
SWEETSOUND2001's Avatar
one word...
why?
Old Apr 25, 2001 | 11:46 PM
teejnut's Avatar
y would u want to do such a thing? aren't both engines "basically" the same.........?
Old Apr 26, 2001 | 01:06 PM
WhteMax's Avatar
ummm
well a 4th generation maxima has 190 horses and um the new maxima has 222 right??? ok then well say your car has ova 200,00 miles on it right and u are going to put a new engine it it.. ok eight... then u could purchse a new engine with 222 horses and if u put a supercharger on it.. well i think u get the idea...
Old Apr 26, 2001 | 03:17 PM
Ravq's Avatar
It's my understanding that the engines are the same with the 5th gens having a slightly modified exhaust and intake. Thus the slight increase in horsepower. Still attainable on the 4th gen engine. It would be cheaper to just get a 4th gen engine I would assume, especially if you plan on swapping engines. It'll save you a few dollars that could go to the SC.
