Problem starting in cold weather; rough idle!
Old Jan 28, 2005 | 09:44 AM
AdamW's Avatar
I was wondering if anyone could help me out. I took my maxima to get looked at because it has trouble starting in the cold unless i give it a little gas, also it has a very rough idle when stopped in drive. I was told it needed a new idle control valve. Could anyone give me some insite on this issue?
Old Jan 28, 2005 | 02:30 PM
cman2004's Avatar
I had a problem with my idle as well. The fix was simple with mine, the idle intake needed to be cleaned. If that intake gets clooged with any sort of build-up it will cause your car to sputter and sometimes stall. That maybe something to ask the mechanic. It's a cheap fix if that happens to be the problem. It worked for me. Hope that helps.
Old Jan 28, 2005 | 02:33 PM
MaximaSE96's Avatar
Maxima Owner
clean ur throttle body if that dont work then it might just be the idle control valve
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
mclasser
Aug 23, 2015 09:32 PM
kirkhilles
Aug 8, 2015 10:53 AM
