95 Maxima Engine Ticking Noise
Old Jan 28, 2005 | 02:23 PM
Horace's Avatar
Is this normal? Whenever the engine is running I hear ticking noises about 4 ticks per second. I just got an oil change and still the ticks are there.
Old Jan 28, 2005 | 02:35 PM
cman2004's Avatar
I'm no expert but the first step is figuring out where the sound is actually comming from. Is it coming from the engine or the transmision/clutch, or exhaust. Once you have determined that you might be able to narrow the problem down. It's not much but it may help.
Old Jan 28, 2005 | 04:05 PM
maximaintheface's Avatar
fuel injectors are kinda noisy
Old Jan 28, 2005 | 04:08 PM
s0ber's Avatar
our fuel injectors sound like crap.
Old Jan 28, 2005 | 04:27 PM
Ant96GLE's Avatar
Yup, it happens all the time... for some reason its more noticable now in the cold..
Old Jan 28, 2005 | 04:47 PM
Horace's Avatar
SO its the fuel injectors?
Would replacing improve performance?
Old Jan 28, 2005 | 04:57 PM
Ant96GLE's Avatar
No, our fuel injectors are just noisy.
Old Jan 28, 2005 | 05:18 PM
Bobo's Avatar
I've never considered my fuel injectors to be noisy and I have never had them serviced, other than an additive that the stealership threw in awhile back. Maybe its something I have to look forward to as my car only has about 56,600 mainly highway miles on it. Those commenting on noisy injectors: have you always felt that way or only after a certain mileage was reached, say 100,000 or whatever.
Old Jan 28, 2005 | 05:19 PM
s0ber's Avatar
Been noisy since I bought it...
Old Jan 28, 2005 | 05:23 PM
Ant96GLE's Avatar
You've never noticed a slight clickety sound? It almost sounds like lifters...
My car has 82k.. ever since I had it at 27k it did it.
Old Jan 28, 2005 | 05:29 PM
2 Da Max's Avatar
its a bomb
or maybe you left your watch under the hood
na that happens to my car aswell, someone told me thats the injectors and thats the way you could tell if you were runing the car hard or not, not sure if its true but thats what he told me. I wonder if those bs injecter cleaners would help against that
Old Jan 28, 2005 | 05:34 PM
Ant96GLE's Avatar
I thought it was your VTEC engaging
Old Jan 28, 2005 | 05:43 PM
2 Da Max's Avatar
my vtec only engages when the overdrive is off
Old Jan 28, 2005 | 05:46 PM
Loe max's Avatar
They only engage at 6,700rpms on an upshift, 6,650rpms on a downshift. Basically, the force is so strong at 6,700rpms that the fuel injectors can't take the extra power and the car feels as though its hitting the rev limiter. All you have to do is upgrade to R34 injectors/ECU and you'll be set.
Old Jan 28, 2005 | 05:52 PM
2 Da Max's Avatar
well ya see if you get the pti ecu with built in rev limiter like me, the ecu lets the injectors no when to WOT cuz you know how that vtec only kicks in at 6700 but trust me, at 6700 in second gear you wont hear the ticking
Old Jan 28, 2005 | 07:12 PM
_maxxedout_'s Avatar
yea the ticking is present here too gotta luv those fuel injectors
Old Jan 28, 2005 | 07:25 PM
Loe max's Avatar
I think the only Maxima after the 1st gen without loud ticking injectors would be the VG-series Maxima's
Old Jan 28, 2005 | 08:17 PM
2 Da Max's Avatar
what causes them to do that? wouldnt a 99 engine suppose to run quiet? do the i30s do it as well?
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
egali045
Aug 16, 2015 01:19 PM
Hawkeye61
Aug 12, 2015 06:45 PM
