Rear Calipers
Old Jan 29, 2005 | 05:26 PM
mwf899's Avatar
Rear Calipers
I took my 98 Max w/ 65k to the dealer for brakes...they said that the rear calipers were shot as well as the rotors and pads, anyone have both of their rear calipers need being replaced...I thought most of the braking is from the front
Old Jan 29, 2005 | 05:29 PM
njmaxseltd's Avatar
Rear calipers are known to be a problem on our cars. You can get aftermarket calipers, pads and rotors much cheaper then Nissan components.
Old Jan 29, 2005 | 06:07 PM
A Flood99's Avatar
i had a rear caliper go out on me, the rubber surround on the piston is what was causing the trouble
i just pulled it off and replaced both of the rear ones....then just replaced the front two and braking is pretty darn good
Old Jan 30, 2005 | 06:43 AM
mwf899's Avatar
Is there any preventive maintenace to keep this from happening again??
Old Jan 30, 2005 | 07:04 AM
Frank Fontaine's Avatar
Yes, the misconception is that calipers are ruined from the outside-in. The reality is they corrode from the inside-out. As brake fluid absorbs moisture, it not only lowers its boiling point, but also corrodes steel components. So the prevent is to flush/bleed the brake fluid and replace with fresh fluid. I have heard that as often as every two years is recommended, but the cost is not that expensive considering how much the hardware costs. I stay away from coolant and brake fluid as they are nasty/toxic substances.
Old Jan 30, 2005 | 12:40 PM
kcryan's Avatar
just did this last week a little less than $500 at pep boys with rebuilt parts all installed. it was a pain in the *** for them but it woulda been alot more at dealer
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
