99 SE Auto - rough 1 to 2 shift
Old Apr 28, 2001 | 07:24 AM
BobMax's Avatar
Are there any known problems in this area ? The car only has 15K miles on it. I plan to take it to the dealer, but I'd like to know in advance if this is a known issue of any sort.
thanks,
Bob
Old Apr 28, 2001 | 08:12 AM
Rutnick's Avatar
thanks,
Bob
Do you really only notice it when the car is cold? If you do, then it is normal.
Old Apr 28, 2001 | 01:03 PM
gtr_rider's Avatar
192.168.1.1
i have hard shifting through all the gears if that tells you anything.
Old Apr 28, 2001 | 02:17 PM
max808's Avatar
thanks,
Bob
I have a 99 GXE auto, smooth shifting for me. I would suggest changing ATF but since your car has only 15K, I'm sure it's still ok. Yes, take it to the dealer, still under warranty. If they tell you something unusual, post it on the forum and see if anyone can help.
Old Apr 28, 2001 | 02:50 PM
Daniel B. Martin's Avatar
thanks,
Bob
The '99 Maxima factory service manual says that too sharp a shock in the 1-2 shift may be caused by ...
1) throttle position switch adjustment
2) transmission fluid line pressure
3) accumulator servo release
4) control valve assembly
5) ATF fluid temperature sensor
The FSM suggests these items be checked in the order specified.
Old Apr 28, 2001 | 07:39 PM
BobMax's Avatar
Where do I go to read the computer codes ?
I suppose I should check them before I bring this to the dealer so I know what's what. But, I'm flying blind here since I don't have my factory manual yet.
Is there a web page that describes the code reading procedure for this model ?
thanks,
Bob
Old Apr 29, 2001 | 08:40 AM
Re: Where do I go to read the computer codes ?
thanks,
Bob
You will find instructions to do a DTC readout and reset
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Old Apr 30, 2001 | 06:37 AM
BobMax's Avatar
Thanks... one more ECU question...
Will the computer store codes without lighting the check engine light i.e. should I bother to check it even if the light is off ?
thanks,
Old Apr 30, 2001 | 06:54 AM
Re: Thanks... one more ECU question...
Will the computer store codes without lighting the check engine light ...
I don't think so... but I don't know for sure.
... should I bother to check it even if the light is off ?
Why not? It's easy enough.
Old Apr 30, 2001 | 02:05 PM
timby01's Avatar
transmission
I had the same prob but i have a 97 SE wind up being the transmission control and solenoid...Dealer even told me this is a common prob
Old Apr 30, 2001 | 02:13 PM
HLDmax
Re: transmission
I have this problem on my 97 GXE auto 79k miles. I tried changing to Synthetic ATF but that did not really help.
How much did it cost to replace the transmission control and the solenoid?
Old Apr 30, 2001 | 02:27 PM
timby01's Avatar
Re: Re: transmission
not sure it was covered under my warranty.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
