Help Please! Check engine light doesn't turn on?
Old Feb 2, 2005 | 11:06 AM
99maxGTR's Avatar
so i've been having this problem on my 99 auto max. When im at a stop, and on the brake the car starts to shake a little and the RPM moves a little up and down, consistent with the shaking of the car. I took it to a mechanic who said that he couldn't find out what's wrong because my check engine light does not come on when i go to start the car. He could not get any information from the computer due to some kind of electrical problem. I don't know what to do and if my car will be ok...any thoughts or suggestions?
Old Feb 2, 2005 | 11:09 AM
MDeezy's Avatar
the buld is blown for the cel and can easily be replaced, I dont understand how he couldnt hook up an OBD-II scanner and check that way.
if you have electrical problem to where you can read from the ecu, I'm sure you car would have a lot more problem if it even would run.
the shaking is probably a mis-fire, sadly 99s are very suseptable to this. I'd take the car to advanced auto or something like that and get a scan for free.
Old Feb 3, 2005 | 09:00 AM
99maxGTR's Avatar
thnx i'll check that any other opinions?
Old Feb 3, 2005 | 09:10 AM
Caracicatriz's Avatar
What was that?
Originally Posted by MDeezy
... I'd take the car to advanced auto or something like that and get a scan for free.
Actually It's Autozone. Advanced Auto doesn't do it.
Old Feb 3, 2005 | 11:28 AM
MDeezy's Avatar
they did it when I went there before. Maybe it depends on the area, or whos working. they just handed me the scan tool and said come back after you scan so I can print out the results.
Old Feb 3, 2005 | 12:52 PM
What was that?
I guess so. That's a trusting place.
Old Feb 3, 2005 | 01:01 PM
PTownMax's Avatar
I still miss the max
ok might wanna consider cleaning you IAC (Idle air controller) that would explain the change in rpm while at idle, as for the vibration that MIGHT go with it, never had that part of problem b4
Old Feb 3, 2005 | 04:12 PM
exit10's Avatar
if the light doesnt go on the bulb could be out or not even there at all, (this is what happened on my car) jus open up the dash and take a look, its all labeled
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
