knock sensor
Old Feb 2, 2005 | 10:29 PM
maximaintheface's Avatar
knock sensor
has anyone just taken the harness off and used a tester to check to see if the harness is bad? is there any way of checking to see if its that besides that if that doesnt work>?
Old Feb 2, 2005 | 11:11 PM
97Maximus's Avatar
Shift_custom
if you think its that.. which is doubtful.. you can take the harness off.. run a piece wire from your battery (touch it to the positve terminal) the connect it to one side of the harness and then take a test light (ground it) then connect it to the other side of the harness and see if youre gettin power through the harness..
Old Feb 2, 2005 | 11:19 PM
i see. i just want to make sure when i get my ks sensor wether or not to get the harness.
Old Feb 2, 2005 | 11:21 PM
i dont see why i just cant use a my tester it will send a signal thew a wire. im just gunna do that . thanks anyways lol
Old Feb 2, 2005 | 11:33 PM
97Maximus's Avatar
Shift_custom
whenever you get your ks in.. unplug the harness and then check the ks ohm through the harness.. if you get a reading ~550K Ohms then your ks and harness are good..
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
