Where's the oil going?
Old Feb 3, 2005 | 08:54 AM
Izzrock's Avatar
My '98 Maxima needs oil from time to time but I don't see any oil dripping underneath or smell any in the exhaust. Any ideas on where it's going?
Old Feb 3, 2005 | 09:03 AM
thefed's Avatar
you're burnin oil
Old Feb 3, 2005 | 10:43 AM
jbreit's Avatar
all engines "burn" a little....up to a quart every 3K is what I consider normal. GM considers a quart every 1000 miles normal. That might be oil going past the rings, or running down the valve guides...but it all end up in the combustion chamber and is burned off.
Don't panic about it
Old Feb 3, 2005 | 10:58 AM
f550maranello2's Avatar
how many miles does ur car have? cuz u are burning oil if u aint leaking it. a quart of oil every 3k is a lot man, that doesnt seem right its more like 1/2 quart or less depending on milage. do a simple test... have someone floor the car and stand behind the exhaust pipe... if you see blue smoke its oil... good luck
Old Feb 3, 2005 | 11:00 AM
|Bijan|'s Avatar
UCF Lexus
Does your oil light flicker on and off??
Old Feb 3, 2005 | 11:08 AM
MaxKlinger's Avatar
A quart every 3000 miles is NOT NORMAL, especially for a VQ30DE...and comparing a GM to a Nissan is like comparing a Big Mac to Filet Mignon.
Granted, every engine does burn very little amount of oil, but it should be negligable, a few ounces at every oil change...certainly not enough to require adding oil. I've got 202,000 miles on my engine and it's never shown an indication of burning or losing oil.
How many miles are on your engine? How much oil are you adding, and how often? Are you running forced induction? Do you get blue smoke from the exhaust when you rev the engine? I suggest you do a compression test, that might indicate if you have very worn piston rings or a valve seats. Also, what kind of oil are you using?
Old Feb 3, 2005 | 01:12 PM
KCMaxima98's Avatar
My car loses a little over a quart every 3000 miles or so. I have a seeping rear main seal but it never leaves any puddles. I think that mine is burning oil too because I just don't see how that much oil is coming out of that seal. If it was there would at least be a couple of drops of oil on my driveway. There isn't, just an old oil stain from the old accord.
Old Feb 3, 2005 | 03:31 PM
lilaclucymaxima's Avatar
Team Ramrod
RAAAARRRR maybe the oil monster ate it
Team Ramrod
yur burnin oil
Old Feb 3, 2005 | 03:39 PM
Jeff92se's Avatar
I'm needing a caw
Please explain in technical terms why the fact if the oil light was/wasn't flickering would affect the oil level.
Old Feb 3, 2005 | 04:42 PM
mansurxk's Avatar
im assuming bijan was joking...his oil light turned on when his oil pump failed, he knows well waht that oil light is for.
Old Feb 3, 2005 | 04:43 PM
Jeff92se's Avatar
I'm needing a caw
I will never overestimate that boy's mechanical skiltz.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
