High Beam Trouble!!!
Old Apr 28, 2001 | 10:16 PM
Mystical Max
my left high beam seems to have burnt out both of my lows work fine but when i switch to high the left one is out any suggestions
Old Apr 28, 2001 | 10:37 PM
tunedup's Avatar
had a similar prob
it would go out and then come back
and then a week later i saw the the harness had melted
i had to go and buy a 9004 socket ...
funny thing was i waas running stock watted aftermarket bulbs
YES StoCK Wattage!
Old Apr 28, 2001 | 10:57 PM
Mystical Max
hmm iC iC ill have to check it out next weekend im also running stock wattage bulbs wierd any other suggestions
Old Apr 29, 2001 | 10:00 AM
Daniel B. Martin's Avatar
This symptom could be caused by a faulty combination switch. That's the column-mounted switch you use to turn the lights on and off.
Old Apr 29, 2001 | 03:29 PM
Mystical Max
ahh i tink ill hve to take it to the dealer now thanx for the info
Old Apr 29, 2001 | 03:47 PM
Rit's Avatar
Rit
Swap your bulbs - maybe you just have a burned
out headlamp.
Old Apr 29, 2001 | 05:42 PM
Re: Swap your bulbs - maybe you just have a burned
Originally posted by Rit
Swap your bulbs - maybe you just have out headlamp.
Rit has given the best advice! Always check the simple things first.
Old Apr 29, 2001 | 06:15 PM
Mystical Max
i should try that but my lows work so i believe its something in the wiring
Old Apr 29, 2001 | 06:20 PM
Your headlight bulbs have two independent filaments, one for high and one for low beam. The fact that your low beams work proves only that the ground side of the circuit is good.
Old Apr 29, 2001 | 06:54 PM
Mystical Max
oOo i did not realize that they had 2 seperate filaments i thought they only had seperate wiring ok well thanx for the info il make sure i check it out
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
zmcneely13
Sep 26, 2015 02:26 PM
