Need advice/help on changing Water Pump
mechanics in my area want anywhere from $400 - $600 (labor only) for this job, so I decided I should try this myself before shelling out that kind of money.
I read the "how-to" guide to changing the water pump. I have a '96 Max GXE and wanted to know if anyone here has tried changing their water pump WITHOUT removing the passenger side motor mount. If so, how did you manage to remove the water pump cover? The Maxima manual says you have to lift the engine on a hoist to remove the motor mount in order to access the water pump.....
Also, did you change your O Ring seals? If so, how difficult/easy is this when changing out the water pump?
Finally, does anyone else have a write up on how to do this with more pics?
Thanks!!
Thanks!!
What about the camshaft/crankshaft seals -- are these the same as the "o" rings?
Finally, how long did it take you to get the pump out? Any pointers you can give me?
It looks like it would take forever and a day to get that sucker outta there. It's a real tight fit!!!
Hmmm. I really don't know about camshaft or crank seals. I think that's beyond my expertise. I mostly followed the "how to" by Mishmosh. Getting the pump out was a really tight fit, but after trying several different positions it finally just popped out. Hardest part was putting in the new timing chain tensioner. It is all done by feel, not sight. After that was in, everything went back together really easy.
MAximalmax: you also managed to remove the timing chain tensioner plate cover without removing the engine mount? I can picture the water pump cover has a little more clearance, but I can't picture the timing chain tensionner plate being removed without removing the engine mount.
The camshaft and crankshat seals are not rubber o-rings. They look like a rubber seal mounted on a steel ring, with an circumference spring to help close the gap between the rubber and the shaft. Each cost between $5 - $10.
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
brichi
Sep 14, 2015 05:23 PM
