Transmission problem?
Old Feb 9, 2005 | 03:49 PM
acmax95's Avatar
Okay, here's my current problem. I cleaned my throttle body the other day and got check engine light afterwords. I reset the ECU and no more light, so i guess thats good.
Anyway, i have what i think is a transmission problem now. I will be driving along and it seems like the car will downshift. As im driving i feel the throttle slow then it speeds up again. When it picks up the car kind of jerks like a bad shift, sometimes it is really hard.
Could this have anything to do with me cleaning the throttle body the other day. I remember seeing something about a throttle position sensor, could i have screwed something up.
Thanks.
P.S. Its an auto with about 160k on it. just had transmission flush about a month ago at dealership.
Old Feb 9, 2005 | 04:18 PM
njmaxseltd's Avatar
You should have pulled the code when the CEL came on. That would have probably pointed you in the right direction. You may not have a tranny problem, but rather an engine issue. Make sure you didn't disconnect the drop resistor when you took the air cleaner top off.
Old Feb 10, 2005 | 06:42 AM
acmax95's Avatar
Thanks for the reply. But where is the drop resistor.
Also any other suggestions?
Old Feb 10, 2005 | 08:19 AM
eturnl
i think i have the same problem, minus the TB cleaning and the sudden jerks, but defininatly the RPM drops... it just started happening on its own.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
