Blue Led Window Switches, Just Some ?'s About The Rears
Old Feb 12, 2005 | 07:27 PM
G4nismo's Avatar
i'm thinking about doin the you know blue led conversion llike many others.
i noticed that the maximas below 97s don't have the little squarish looking LED for the rear switches. could i possible just buy the 96 switches and hook em up to a 97?
also for the driverside, i heard there has been some accidents due to leavin the led prongs too long. other than that its pretty simple right?
heres some how to pics of a 96 that is.
Image of left rear door handle
Old Feb 12, 2005 | 07:32 PM
Black Maxima
I bet you could change the 97 switches with a 96. It was easy to do my 96 rear switches. Just put the new ones in just like the factory ones.
The driver's switches were the hardest of them all. Just cut the contacts on the other side short and you won't have problems. The hard part is soldering them straight so you dont get "hot spots".
Old Feb 12, 2005 | 07:36 PM
G4nismo's Avatar
so the plugs should be the same? is this just for the 96 and 95s, or wht about 98s and 99s?
Old Feb 12, 2005 | 07:45 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
are you saying the LEDs on the 97+ switches are the small flat square LEDs? you can buy thoes too, oyu just use some de-solder ot get the current ones off then solder on the ewn ones.
Old Feb 12, 2005 | 07:51 PM
G4nismo's Avatar
no believe me, there really really small, i don't think anybody sells them. think of it this way, those things are smaller than a half the size of a 3mm led.
Old Feb 12, 2005 | 08:00 PM
Vlasic's Avatar
ok. can you tell me if they are really small and flat? got any pictures? i know i have seen the small flat LEDs for sale before, but cant remember where. im sure you can also just solder some 3mm leds to the connectors. if you got some nice close up pics i could help more.
Old Feb 13, 2005 | 07:10 AM
Black Maxima
So you are saying the 97+ switches have small LED squares? I bet you could just desolder those and solder regular LEDs in there. Maybe the previous owner modified them a little bit. Try it and let everyone know how it's done.
Old Feb 13, 2005 | 09:11 AM
dawalkster's Avatar
is craving Bojangles
http://www.cardomain.com/memberpage/479058/3
that site shows you how to change the square leds to regular ones. but im pretty sure if you wanted you could just go to a junkyard and pick up some 95 or 96 rear boards and use those. also make sure when you do it that you dont lose the black plastic pusher things in the switch that the switch needs to work. especially on the driver side cause there are 12 of them i think and if you turn the board over and dont realize what your doing they will all fall out and your stuck searching for a little black piece of plastic. when i did mine this weekend i didnt realize they fall out so easily and i lost 1 of these little biotches and now i hafta go to a junkyard just to get one little piece of plastic. grrrrr
Old Feb 13, 2005 | 10:02 AM
Black Maxima
Yes, those little, black, plastic things do fall out if you don't know what your doing. I thought I lost one, but noticed the driver's window only has 3 out of the 4 functions. It doesn't have a AUTO UP, so it only needs 3 plastic pieces.
My Blue LED swithches look []D [] []\\//[] []D
Old Feb 13, 2005 | 12:36 PM
dawalkster's Avatar
omg thats brilliant, gah its so obvious now. i think i found my last plastic thing. thank you !!!
Old Feb 13, 2005 | 04:51 PM
Black Maxima
Old Feb 14, 2005 | 10:42 PM
G4nismo's Avatar
here is a pic of the rear led, couldn't get close up.
i heard one way is to remove the chip underneath it. hell no
Old Feb 14, 2005 | 11:11 PM
illmortal's Avatar
can't see picture
Old Feb 15, 2005 | 09:03 AM
Chunger's Avatar
My other car is a Hybrid
FYI, the 96 rear harness does not fit the 97.
Old Feb 15, 2005 | 01:18 PM
G4nismo's Avatar
theres 4 prongs.
Old Feb 15, 2005 | 02:17 PM
G4nismo's Avatar
yeh i checked out the how to site on cardomain. you have to remove the led and then connect the new led prongs in one of the 2 of 4 holes. second thought, doesn't seem that hard beside tryin to place the led
Old Feb 15, 2005 | 02:18 PM
Black Maxima
It will be easy.
Old Feb 15, 2005 | 02:31 PM
G4nismo's Avatar
pavelsmax also gave me this site that actually sell those leds:
http://search.ebay.com/smt-led_W0QQsojsZ1QQfromZR40
but there gonna be bright as reg leds so i might stick with 3mm despite how harder there gonna be instlaltng
Old Feb 15, 2005 | 06:24 PM
Igobuk's Avatar
Just remove the tiny LED and solder on a regular LED like pictured below. The longer lead in the picture is the positive LED, the negative lead goes to the stock resistor. I know that sounds contradictory but that's how it will work.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
kjm900r
Aug 5, 2015 07:14 AM
