Did I do something wrong with my brakes?
Old Feb 18, 2005 | 04:54 PM
97BLKMAXSE's Avatar
I replaced the rear pads today on my '96 and the pedel seems very soft and travels to far. I bled the lines and that helped a little but they still dont feel right. Im not sure if i bled them right tho. Should the car be running when its done? Also the haynes book says to disconect the abs actuator, not sure were that is so i just took the fuse out for the abs. Im not sure if new pads need some breaking in time or mabye do i need to adjust the brake booster. Any help is greatly appricated. thank you
tom
Old Feb 18, 2005 | 04:56 PM
urmab's Avatar
You might of gotten some air in your breaks bleed the breaks and that should fix it
Old Feb 18, 2005 | 05:05 PM
97BLKMAXSE's Avatar
I did bleed them but im not sure if i did it right. the haynes book doesnt explain very well.
Old Feb 18, 2005 | 05:30 PM
JSniper0's Avatar
ok....what did u do to bleed them?
Old Feb 18, 2005 | 06:26 PM
97BLKMAXSE's Avatar
I bled one caliper at a time (due to not having jack stands) with the car off. i then tried it with the car on. both times with the abs fuse out. the haynes book says to disconect the abs actuators, but i dont know where they are, so i didnt. both times about 1 tablespoon of brake fluid came out of each caliper.
Old Feb 19, 2005 | 06:00 AM
njmaxseltd's Avatar
You couldn't have bled them correctly if only 1 tablespoon came out.
Do this, and have a buddy help you. Car off, you don't need to do anything to your ABS system. Put a vacuum hose on the end of the bleeder valve on the caliper and point the end into some sort of can. Have your buddy put his foot down hard on the brake pedal. Open the bleed valve, fluid will come out and the brake pedal should go to the floor, then close the bleed valve BEFORE YOU LET GO OF THE BRAKE PEDAL. Once the valve is closed, have your buddy release the pedal. Repeat this about 5x per side. Make sure you have plenty of fluid in the master cylinder.
EDIT: Also make sure the notches on the caliper piston are lined up with the nub on the rear pads. The piston notches should be lined up to 12 o'clock, 3, 6 and 9. Like a plus sign +
Old Feb 20, 2005 | 01:31 AM
ThurzNite's Avatar
njmax, does it matter what order you bleed in?
Jae
Old Feb 20, 2005 | 06:33 AM
maxima_kenny96's Avatar
Your lucky if you have ABS...my 96 SE doesnt
Old Feb 20, 2005 | 08:30 AM
njmaxseltd's Avatar
Jae
Not really...
Old Feb 21, 2005 | 12:39 AM
ThurzNite's Avatar
Originally Posted by njmaxseltd
Not really...
Oh. I guess Autozone needs to change their Service Manual
http://www.autozone.com/servlet/UiBr...3d801f5a99.jsp
1. Right rear caliper
2. Left front caliper
3. Left rear caliper
4. Right front caliper
Jae
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
