60,000 mile tune up WORKS GREAT!!
Old Feb 20, 2005 | 06:50 AM
hiphipmaxima's Avatar
hey guys i've had my maxima for a while now and i just recently joined the org. (i just found out about it)
i did the 60K tune up and i an feel the difference
i spent about : $334.00
everything that i did
oil change
oil filter
fuel filter
pcv valve
top up on all fluids brake, tranny, rad.
clean engine bay
spark plugs
seam foam the motor
clean air filters with k&n air cleaner
changed the belt
cleaned the throttle body
tighten the throttle body cables
new knock sensor
new egr valve
reset ecu
feels like a brand new car
highly recommended
Old Feb 20, 2005 | 07:11 AM
|Bijan|'s Avatar
UCF Lexus
Changed THE belt? Which belt?
What kind of spark plugs?
Where'd you get it done?
That seems like a good price.
Old Feb 20, 2005 | 07:20 AM
maxima_kenny96's Avatar
you prolly couda saved ALOT of money if you did it urself. but I have also been thinking about doing it...seeing as...well...my car is going on 79k and it has 1 tune up in its WHOLE life and that was at 30k
Old Feb 20, 2005 | 10:37 AM
i did it myself
Old Feb 20, 2005 | 10:52 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
oil change
oil filter
fuel filter
pcv valve
clean engine bay
spark plugs
seam foam the motor
changed the belt
new knock sensor
new egr valve
reset ecu
highly recommended
Cleaning Engine Bay, added additional 20 HP. Made my car run so much better.
Just joking.
Old Feb 20, 2005 | 12:53 PM
fadeaway's Avatar
Go Hokies!!
Look at all the stuff he did/replaced.. not a lot at all.
Old Feb 20, 2005 | 01:05 PM
Batxel's Avatar
blah
look at the list again. The knock sensor will be around $100 it self not to mention if he used syntheic oil for his engine and tranny. Just those three things could get him over $200
Old Feb 20, 2005 | 03:21 PM
Bobo's Avatar
Why did the knock sensor and EGR valve require replacement at that low mileage?
I have 57,000 miles on mine and none of that stuff requires replacement. As well it idles perfectly and has never had the throttle body or IACV cleaned.
Old Feb 20, 2005 | 03:35 PM
h2kPinkPnthr
i have 127K miles on my car and i havent done any of that except for plugs and knock sensor. Ive really been considering replacing the egr and cleaning out my intake, do you think that it will be worth it?
Old Feb 20, 2005 | 03:58 PM
MDeezy's Avatar
I have 116K and have only done sparks and oil and such. Up on the next comming weeks will be Oil/Tranny/Sparks(NGK finally).
Is there really a need to replace the PCV if there is nothing wrong with it? I cleaned mine with Carbon Cleaner and a tooth brush, but is replacing really necesarry if its not faulty?
Old Feb 20, 2005 | 04:02 PM
Turk's Avatar
Just joking.
Damn i got 15hp, what did you do to yours that you got extra 5HP. I am just curious.
Anyways, the one i noticed right off the bat was that the TB cleaning, noticed diffrence right away.
maxinout93
Oct 27, 2015 01:29 PM
Tbone3944
Sep 29, 2015 09:04 PM
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
