*PIC* Busted CV boot. Is there any hope?
Old Feb 20, 2005 | 04:35 PM
SkoorbMax's Avatar
There's the right CV boot on my 97. I guess I should have replaced it a while ago Anyway, my cv joint is likely dead now isn't it...? Do I need to replace the entire axel, and is it hard? I see motorvate has a write up on that. It doesn't look that difficult by simply looking at what the axel is.
In regards to driving the car drives fine and I was unaware of this until changing the oil today, so I plan on putting another 500+ miles on the car this week before probably getting to it next weekend.
Old Feb 20, 2005 | 04:51 PM
WaarrEagle's Avatar
You should replace the entire axle since you do not know when it tore. When you drive on it like that dirt gets in there and can ruin the joint over time. I bought my new axle from raxles.com - they sell new axles unlike Autozone, etc. Replacing it isn't too hard. Just follow the instructions on www.motorvate.ca .
Old Feb 20, 2005 | 05:27 PM
bkrchrdsn's Avatar
I just replaced both of my axles due to busted boots on my 98 maxima. It was a cheap repair for about $130 tax included and didn't take but a 1hour 15 minutes to do both sides. Good luck
Old Feb 20, 2005 | 05:30 PM
MDeezy's Avatar
Hot damn that looks like mine.
yea just replace the whole thing unless you really want to have to take that all apart and clean and repack . . . a lot of work, best to get a new one.
Old Feb 20, 2005 | 06:36 PM
SkoorbMax's Avatar
Raxles looks like a good bet. They have no prices online - how much do they typically charge?
Looking at motorvate it seems that he spent so long with labour because he was repacking and applying a new cv boot. I guess with a new axle, though it's pricier, it's really just a quick swap (once the wheel comes off)...
Old Feb 20, 2005 | 08:28 PM
Hunter11's Avatar
Between motorvate and the Haynes manual, are those good enough sources for me to look at on instructions to replace the axle? Or is there another link to better instructions? Thanks!
Old Feb 20, 2005 | 09:08 PM
Chief Brody's Avatar
I am wondering the same. I would like a bit more explanation of removing the driveshafts at both the inner and outer CV joint ends. To all those who did this, what are some tips you can give?
Old Feb 21, 2005 | 06:27 AM
SkoorbMax's Avatar
Bumperoos!!
Old Feb 21, 2005 | 06:51 AM
Torgus's Avatar
goto raxels
install is easy...just make sure each axel has 'clicked' into place. no one wants to know what an axel shooting out at 30mph is like...
Old Feb 21, 2005 | 09:49 AM
MDeezy's Avatar
motorvate is an excellent write up, he goes thru it step by step, and tell you all the tools and greeses you'll need. I believe Motorvate is the best write up out there if you cant follow that write up then just replace the whole axle it will be much easier and less of a headache for you.
Old Feb 21, 2005 | 12:42 PM
DRIFFT MAX
were on raxle.com cant find cuz i need new axles both.....
Old Feb 21, 2005 | 12:48 PM
MDeezy's Avatar
just e-mail then and ask for a price quote and how to order.
I think you have to call in to order
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
