Air intake problems
Old Feb 21, 2005 | 05:21 PM
InsneDrmr's Avatar
Air intake problems
I put in my cold air intake...but I have a problem. I found yet another sensor on the intake tube towards the bottom end. This sensor has no where to go on the new intake, so i reconnected it and let it dangle more or less. The service engine soon light came on and I dont know what I should do. Drill a hole for the sensor? or not. Or should I just put the bottom end of the stock intake back in so the piece has a place to go and hopefully gets some use. Get back to me soon. Thanks!
Old Feb 21, 2005 | 05:24 PM
96white's Avatar
what brand intake is this ? Most name brand name companies have that hole for the sensor. I know place racing does.
Old Feb 21, 2005 | 05:26 PM
InsneDrmr's Avatar
Its a bomz. I used the stock piping up to the MAF because I couldnt get it off. But the pipe itself has no place to put it.
Old Feb 21, 2005 | 11:10 PM
maximazation's Avatar
that sensor is the IAT (intake air temp) sensor, when i had my old short ram intake, i just taped it on the filter, no CEL. worked fine for me
Old Feb 23, 2005 | 02:30 AM
Turbo1er's Avatar
Doin' it 4 da shorteez
I have a hole cut in the pipe and drilled it in there, i am glad I did it to, I went brain dead one day it was pouring out and attempted to get home, hit an area that had quite a bit of water build up and had nowhere to go but straight through it, it sucked up a little water but the sensor shut her down before anything really bad happened, cleaned her out and she was good as new.
Old Feb 23, 2005 | 03:58 AM
Chickan's Avatar
somehow I'm thinking that that sensor only detects air temp, doesn't have anything to do with killing your car once it gets water in it. Correct me if I am wrong though ..
Old Feb 23, 2005 | 04:08 AM
2 Da Max's Avatar
no that was your maf detecting water
Old Feb 23, 2005 | 04:28 AM
Turbo1er's Avatar
Ach, thats right me, well, I still drilled the sensor to the pipe.
Old Feb 23, 2005 | 04:37 AM
jackiss2888's Avatar
same deal with me... still read temp. on the instrument panel correctly too.
Old Feb 23, 2005 | 06:21 PM
InsneDrmr's Avatar
I dont know what to do with it, i reconnected the sensor and let it dangle and it did nothing, It was weird, the "service engine" light didnt come on until the second time the car was started with the intake in it. Is there anything else that may be causing the problem, or is it definatly this sensor. thanks again guys.
Old Feb 23, 2005 | 06:27 PM
happyricefob's Avatar
V^___^V
just stick the sensor in ur midpipe. i have not encounter this problem for 2 years+....
Old Feb 23, 2005 | 06:38 PM
InsneDrmr's Avatar
so basically just drill it in there eh? Nothing else is causing the problem though you think? I dont mean to question you, just making sure.
Old Feb 23, 2005 | 07:42 PM
Crockpot's Avatar
or instead of this guess and hoping your SES will turn off, pull the codes.. so you know what your problem actually is...
Old Feb 24, 2005 | 01:56 PM
InsneDrmr's Avatar
All the sensors are now hooked up, but the check engine light is still coming up, how can I go about finding out whats wrong.
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Sep 10, 2015 04:29 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
nbstriker10
Sep 4, 2015 04:26 PM
