transmission question
Old Feb 24, 2005 | 01:08 PM
MAXTOUT's Avatar
Ok, so I found a trans to replace my failed trans. 97 I30 locking diff. 69K with 90 day warrenty for $700 shipped. Is this a good deal or should I continue looking?
Also, this should be a direct swap for my 97 Max SE, right?
thanks
Old Feb 24, 2005 | 01:21 PM
JDM_Maxima's Avatar
you can always look, but if that one is in your price range, why not get it?
it has a 90 day warranty too and it a ,limited slip sounds like a pretty good find.
if you dont take it someone else on the org will.
Old Feb 24, 2005 | 01:43 PM
tavarish's Avatar
fwd gone rwd cr00
it sounds good to me...
Old Feb 24, 2005 | 02:04 PM
MAXTOUT's Avatar
Well, i talked to my cousin(a mechanic) and he said it was a great deal. I purchased it today and I expect it about mid next week.
I think I am going to get a new clutch while I have everything apart. Ebay Exedy clutch, since I don't plan on doing any more modding.
Old Feb 24, 2005 | 02:06 PM
Nismo3112's Avatar
Custom User Title
You will need different CV shafts I think.
Old Feb 24, 2005 | 02:08 PM
MAXTOUT's Avatar
I thought I needed different shafts if it did not have ABS. My max has ABS and I am assuming that the I30 would have ABS. I am sure that I would need different shafts if it was a 5th gen trans swap, but that does not apply here.
Old Feb 24, 2005 | 02:09 PM
Nismo3112's Avatar
Custom User Title
I think the shafts are different between an LSD and open diff tranny.
Old Feb 24, 2005 | 02:14 PM
MAXTOUT's Avatar
great, thats all i needed. I guess I will wait for someone to chime in who knows if the parts are compatible.
T
Old Feb 24, 2005 | 03:27 PM
JDM_Maxima's Avatar
the cv shafts for a limited slip tranny and open differential are different.
the vlsd shafts are bigger from what i have been told. if you where to get a 5th gen tranny with open differential you would be able to use the same axles
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
videomano
Sep 8, 2015 03:28 PM
