IACV location pic? .. for cleaning
Old Feb 25, 2005 | 09:07 AM
MAXRB8's Avatar
Hey guys, I did the throttle body cleaning about a year ago, but I'd like to clean the IAC valve, I found the write up in the stickies, but I was wondering if anyone had a pic of where exactly it is located? thanks
Old Feb 25, 2005 | 09:19 AM
mzmtg's Avatar
Minister of Silly Walks
Right next to the TB, on the upper intake manifold. It's got 2 purple plugs on it.
Old Feb 25, 2005 | 09:37 AM
big_al's Avatar
yeah right behind the throttle body. I think it has 3 or 4 plugs going to it.
There's also a gasket that seals it to the intake manifold.
Old Feb 25, 2005 | 10:47 AM
BlackCat's Avatar
RIP '98 Maxima SE
Its #11 in the pic below from the thread:
http://forums.maxima.org/showthread.php?t=365653
Old Feb 25, 2005 | 10:51 AM
MAXRB8's Avatar
Now that's what I'm talkin about! Thanks.... once again, Blackcat! See you at the meet soon!
Old Feb 25, 2005 | 11:46 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'm going to try cleaning it tomorrow morning. I had planned to pick up a PCV valve after work but I had to order it instead. $17.99 for a PCV valve...
Note: $17.99 Cdn!
Old Feb 25, 2005 | 11:56 AM
Chickan's Avatar
http://www.courtesyparts.com/Merchan...de=11810-00011
$8.61+s/h
Old Feb 28, 2005 | 05:54 AM
lefty
Is an aftermarket PVC valve fine to use over an OEM?
Old Feb 28, 2005 | 07:00 AM
96white's Avatar
NO ! Do not use aftermarket PVC, they tend not to be the right spec, I have seen issues with anything less then OEM. They are not that expensive, do it right the first time.
Old Feb 28, 2005 | 10:58 AM
dialect1luv's Avatar
what does the pcv valve do?
and what does cleaning the iacv do?
thanks
Old Feb 28, 2005 | 11:34 AM
96white's Avatar
please read the F.A.Q. thread
Old Feb 28, 2005 | 11:39 AM
BlackCat's Avatar
RIP '98 Maxima SE
I didn't get a chance to clean the IACV but I did take a look to see its location and the bolts. There's this little bracket-thing in front of the bolt thats closest to the firewall. How do you get at that bolt? With an open end wrench?
Maximan190
Dec 16, 2015 06:01 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
