Mannual Climate Control HELP!
Old Feb 25, 2005 | 10:15 PM
sniper615's Avatar
help! help!
guys i need some help.
i have a 95 se 5 speed and my Mannual Climate Control will only work when it's put to 4. i tried changing the unit and it's the same problem. guys i'm stuck. HELP! please post replies
Old Feb 25, 2005 | 10:46 PM
Kinger402's Avatar
It is probably your blower motor resistor....It is like a 20 dollar part that resists electricity going to your blower motor..that is how it is able to get to 1-2-3 speeds. That is the reason your unit only blows out air on speed 4 and no air at the other speeds
Old Feb 26, 2005 | 01:31 AM
sniper615's Avatar
where is it located
Old Feb 26, 2005 | 07:08 AM
sniper615's Avatar
bump, bump, bump
Old Feb 26, 2005 | 11:09 PM
sniper615's Avatar
bump, bump, bump still need help guys
Old Feb 27, 2005 | 01:13 AM
wariow's Avatar
try whacking it a coupla times.
Old Feb 27, 2005 | 03:59 PM
blaze0ne
from 4th gen FAQ
http://forums.maxima.org/showpost.ph...2&postcount=32
Why does my A/C only work on fan speed 4?
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
There is a good photo of the blower motor and resistor assembly in the Haynes repair manual, page 3-8. If you don't already have a copy of this book, please get one. It will be money well spent.
a) Move the front pass seat all the way back (for convenience)
b) Remove a harness connector (with 4 wires I think) running into the bottom of the blower motor.
c) Remove the 2 philips screws that hold the blower motor resistor in place.
d) Put new one in, reverse install.
Blower Motor Resistor Part Number: 27150-1E405
You can get it here:
http://www.nissanparts.cc/cart/?pn=27150-1E405
Should be $28 at your local dealer. It's $28 delivered from discount Nissan parts sites.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
