Tailights not working ???
Old Feb 28, 2005 | 12:40 PM
Assassinroon's Avatar
Hey i have a 95 maxima and it seems my taillights are not working. The brake lights corner signals and headlamps are working but thats all. The front corner lights and the back 2 tailights wont turn on when the lights are on. I changed the fuse and everything went back to normal and worked but then the fuse blows again within a day. I have gone through 4 fuses in a week someone can you please tell me what the problem is.
OH and i checked my ecu code i just have a bad knock sensor
Old Feb 28, 2005 | 12:51 PM
tavarish's Avatar
fwd gone rwd cr00
sometimes it's not just that one fuse...
Old Feb 28, 2005 | 01:26 PM
oh so i should check all the fuses yep stupid me ill get on that and post later
Old Feb 28, 2005 | 01:30 PM
Batxel's Avatar
blah
Something is probably shorted. What size fuse did you replace it with and which of 2 fuses for the parking lights are you replacing?
Would you happen to be using the parking lights as signal for a relay or did the brighter corner light mod?
For reference there are 2 fuses. A 15A fuse under the hood labled as tail and a 7.5A fuse labeled as Tail L behind the dash board.
maxima_kenny96's Avatar
maybe sumtin is shorting out CAUSING you to blow all those fuses.
Old Feb 28, 2005 | 04:53 PM
ya i did the clearance bright mod i changed the 7.5 a fuse should i change the one under the hood also ?
Old Feb 28, 2005 | 05:17 PM
96white's Avatar
Moisture could also cause this from a crack in a light somehwhere. I found when this happened it was just a fuse for me.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
