2001 5th gen flywheel, tranny, clutch in a 96?
Old Feb 28, 2005 | 01:26 PM
borka's Avatar
I am getting a 2k1 tranny for my 96 max and im also getting a 5th gen clutch, pressure plate and flywheel along with the tranny, i know the tranny and clutch would fit.
1. will the flywheel fit?
2. any benefits to put the 5th gen flywheel?
3. how much does a 5th gen flywheel weight?
Old Feb 28, 2005 | 07:43 PM
nismomax98's Avatar
tranny will fit but the 4th gen axles wont
just get the fidenza flywheel u dont need the 5th gen flywheel it has no advantages over the stock 4th gen they are the same i belive
fidenza 4 th egn flywheel($330-400) weights about 12-14 lbs stock 28-30 lbs(used $75-120)
Old Feb 28, 2005 | 07:50 PM
2 Da Max's Avatar
whats good about the 2k1 tranny? stronger?
Old Feb 28, 2005 | 09:27 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I'm certain you are not speaking from experience, because my 4th gen axles fit fine in my 5th gen tranny. He didn't mention AE LSD tranny so he can reuse both axles.
2K+ transmissions have reinforced 2nd, 3rd, and 5th gears.
Old Feb 28, 2005 | 09:28 PM
Goran's Avatar
what's better combo: fidenza FW/exedy stage 1 or fidenza/5th gen clutch?? Is there a point of getting aftermarket clutch if you have a almost stock car?
thanks
Old Feb 28, 2005 | 09:29 PM
JClaw's Avatar
Actually:
Fidanza= 11 pounds
Stock 4th gen flywheel= 18 pounds
Stock 5.5 and 6th gen 6-speed flywheel = 31 pounds.
Old Mar 1, 2005 | 07:42 AM
borka's Avatar
The 5th gen flywheel im getting is free, I just paid for the tranny ($850+50shipping) and they threw in the clutch,pp,flywheel from that car w/ 37K miles for free
So im thinking since my car has 167K, ill put a lower mileage flywheel in there....
Do 5th and 4th gen flywheels weight the same?
Old Mar 1, 2005 | 08:35 AM
nismomax98's Avatar
well thats great for u and thanx for pointing out my mistakes, I was thinking he had AE tranny sorry
Old Mar 1, 2005 | 08:39 AM
nismomax98's Avatar
Originally Posted by JClaw
Actually:
Fidanza= 11 pounds
Wow people jump at mistakes made but no one out of 25 people who looked at his tread answered any of his questions just point out minor mistakes 11lbs and 12 lbs damn colse in my book and i did say about so
Old Mar 1, 2005 | 11:15 AM
matty's Avatar
You best bet would be to a call a nissan dealer and possibly find out the weight difference if it really matters..
If I were you I would use the 5th Flywheel since it does have less miles on it
My set up is 5th Gen tranny, Fidanza flywheel and Exedy clutch
**one thing when you get your car back, your shifter will sit alittle bit farther from from the front...all guys that put 5th tranys in their cars have the same thing...I got used to it
-matt
Old Mar 1, 2005 | 01:21 PM
maximazation's Avatar
dont need an aftermarket clutch unless your putting down lots of power, also wont last as long. for almost a stock car, a 5th gen OEM clutch will do you more than well, and also will last 100K miles and grips better than the 4th gen OEM.
Old Mar 1, 2005 | 01:24 PM
borka's Avatar
That is what im getting; 2K1 tranny, clutch, PP,flywheel w/37K miles...
Old Mar 1, 2005 | 01:26 PM
borka's Avatar
-matt
I my Customaxima short shifter sits way too forward and hits the plastic surrounding in 1,3,5 gears, so im guessing now it will be centered?
Old Mar 2, 2005 | 09:12 AM
TooMAX's Avatar
Will a 5th gen clutch fit on a 4th gen flywheel?
Old Mar 2, 2005 | 12:55 PM
yes.....it will
Old Mar 2, 2005 | 12:56 PM
i hope, because i have the same short shifter and while racing, it hits the center console and actually cracked it.
Old Mar 2, 2005 | 01:15 PM
TooMAX's Avatar
yes.....it will
cool.. thanks, maximazation!
Old Mar 2, 2005 | 01:43 PM
Goran's Avatar
Any specific year of 5th gen or it doesn't matter?? Also, would 95-99 fidenza fw work fine with 5th gen clutch?
Matt93SE
May 24, 2019 02:58 PM
maxima-junky
Aug 13, 2015 09:59 AM
sc10692
Aug 9, 2015 09:37 AM
