how often has there been problems with our....
Old Feb 28, 2005 | 04:30 PM
aixgelo78's Avatar
cars having a bad ecu. I am not getting a code. I did all the usual maintenance, both primary o2s, spark plugs, fuel filter, cam angle sensor and checked for continuity from each coil plug to the plug at the ecu and all came out ok. I am not getting a spark on 3 or 4 of my cylinders and I used a "known" good coil pack to check for spark on each cylinder and did not get spark on a 3 of them. Does the activation relays on the ecu board go bad in our cars?
96
5spd
162k miles
thankx chris
Old Feb 28, 2005 | 04:47 PM
Deagle's Avatar
wants the ads to die
I had mine replaced a few months ago for free thankfully.. would have cost $1600 from the dealer
Old Feb 28, 2005 | 04:49 PM
lilaclucymaxima's Avatar
Team Ramrod
my old ecm had moisture on the bottom of it so it was corroded, i had a ton of codes when i had the told one. i replaced it and now i dont have any codes.
Old Feb 28, 2005 | 05:04 PM
aixgelo78's Avatar
thankx for the replys
so ecus do go bad...btw how did you get that ecu replaced by the dealer for free? especially if your car is a 97...
thankx for the input guys
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
