how to install eyelids on a 96?
hey does somebody know how to install eyelids on a 96? what i do with the little nipple on the headlight because it stick out a little ok if somebody know to let me know at ojs81@hotmail.com ok thanks
i had to take a file and a lawn chair and start sanding. then i got tired and got the drill out with a sand paper type wheel and just start grinding it down. takes about 20 mins the most on each side
I believe those nipples are used by special headlight aiming machines/
i took off my nipples with a dremel and a tungsten bit. make sure to use a little water or it might get too hot.
I also used a dremel, but I used a diamond cutting wheel which cut through it like Butta...
http://www.dremel.com/html/images/pr.../large/545.gif http://memimage.cardomain.net/member...3_189_full.jpg |
hey flavor- where did you get the lid for the corner light. that CF look is hot
IonicDynamics :doublethu http://www.ionicdynamics.com/Eyelidnew.html |
Gr8 blend with your CF hood. Nice look.
Age old bump...Didnt wanna start another thread.
I tried to mount my eyelids with double sided tape (not 3m) but it seemed too bulky. It wasnt flush with the lights. Are there any alternative ways to mount em? Something that would withstand the heat from the HIDs. |
Use 3M playa. That's what I used and it was perfect. It withstands heat nicely as well!
Use the heat from your HIDs to mount the eyelids though, it'll make them stick a lot better and they won't come off. |
Are they thinner than the typical double sided tape? Ill check em out.
Originally Posted by VQ'rInWLA
(Post 7950396)
And theyre thinner strips right? I want em flush with the lens.
(Post 7950547)
Ight Ill pick some up tomnorrow. Good looks.
I made custom Eyelids. Used 3m Carbon Fiber Vinyl. They look pretty good and stretch over the nipple.
© 2024 MH Sub I, LLC dba Internet Brands
