retro complete ***PICS***
nice job azmaxipad.
So I am doing the same thing as we speak. I noticed that the bezel from the M3 does not fit the headlight housing of the max. The top part of the circle is too big. Did you modify the bezel by cutting the top or is there a way to make it fit that I am not seeing?
Also, does the Bosch e46 bi-xenon solenoid go on the bottom as in the Hella bixenon or the top? Based on optics, I am guessing the bottom but I am not too sure!
Lastly, please do a write up for the wiring for the bosch E46 bixenon since it is different than the Hella if you can!!!
thanks!
thanks!
you will fry your stock wiring eventually if you run the ballasts directly off of your stock harness. it will work for a while and you'll think that everything is fine but eventually the skimpy stock wiring will fail because the ballasts draws over 3 times the rated current for the stock wiring at startup. a relay is a cheap insurance and there's no reason not to use one.
Originally Posted by azmaxipad
wire? as far as the ballasts and stuff like that? if that is the case the easiest is to cut the stock harness and connect the power and ground. Black to black. and on the wiring harness the center wire is the low beam power that is connected to the red wire off the ballast. I will help you with any of your wiring needs and questions. also www.hidforum.com is a great help. the high beam shutter will be hooked up soon
now I see what my money went towards
amazing I like it..... you did a fantastic job looks like you got stock projectors.... im jealous if your buddy can get anymore and you wouldn't mind shipping them out I am calling dibs on the next setup you can throw together amazing job though congrats and nice modding
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
