Daniel Martin: EVAP canister vent ctrl valve closed...
Old May 3, 2001 | 02:21 PM
starturtle's Avatar
Is this something I can fix myself or should I take my car to Nissan or my mechanic? Thanks
Old May 3, 2001 | 04:11 PM
Daniel B. Martin's Avatar
The answer depends on your mechanical expertise and available equipment, two factors unknown to me.
The EVAP Canister Vent Control Valve is located on the EVAP canister (underneath the vehicle near the left rear tire) and is used to seal the canister vent. It has one hose connection and one two-wire electrical connector. The solenoid in the EVAP CVCV responds to signals from the ECM. When the ECM sends an ON signal, the coil in the solenoid valve is energized. A plunger then moves to seal the canister vent. The ability to seal the vent is a necessary part of the diagnosis algorithms for other evaporative loss system components. This solenoid valve is used only for diagnosis, and usually remains open. When the vent is closed, under normal purge conditions, the evaporative loss system is depressurized allowing "EVAP Control System (Small Leak)" diagnosis. Since this part is used only for brief emissions tests the vehicle will usually start and run well despite a Service Engine Soon warning light on the dashboard.
The EVAP CVCV may be bench tested. Remove it from the vehicle (one hose, one connector, two bolts). Verify that air may pass freely through the valve. Then use a pair of fused test leads to apply 12 volts to the terminals to energize the solenoid. Verify that air does not pass freely through the valve. If the CVCV fails these tests, try cleaning it with WD-40 and compressed air. If this fails to free it up, replace the valve using a new O-ring.
Old May 3, 2001 | 04:50 PM
starturtle's Avatar
Thanks Daniel. Sounds too complicated
I'll have my mechanic or Nissan look at it.
Old May 4, 2001 | 05:31 AM
Albertt's Avatar
Re: Thanks Daniel. Sounds too complicated
Geez.
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
dcam0326
Sep 7, 2015 07:26 AM
