BRAKE LIGHT on for a bit ????????
Old Mar 10, 2005 | 09:58 AM
DRIFFT MAX
driving to class today and saw my red brake light on, the hand brake was all the down and im not sure y the light was on. Do our brake lights come on when were low on brake fluid???
Old Mar 10, 2005 | 10:01 AM
MaDMvD's Avatar
Yes, check your brake fluid. Do you have ABS? What condition are your pads in?
Old Mar 10, 2005 | 10:03 AM
Luvs2speed
yeah I remember when my first brake light came on...I thought it was stuck cause the E-brake was all the way down....if your brake light came on and went off im not exactly sure...but im guessing that your brakes are worn...im pretty sure that when your brake light comes on that theres a sensor on the brakes on the car that lets you know the pads and/or rotors are bad....maybe you just need pads ...take one of your wheels off and check out your pad wear...most likely you can tell if its worn....check the stickys for brake info..good luck!
Old Mar 10, 2005 | 01:49 PM
DRIFFT MAX
Thanks, had brake pads replaced 6 months ago so they should be fine, and i think its just the fluid havent looked will tonight
Old Mar 10, 2005 | 04:10 PM
ThurzNite's Avatar
If you can, get your alternator checked too, just in case.
Jae
Old Mar 19, 2005 | 10:39 PM
DRIFFT MAX
Altenator? why would that cause the brake light in the dash to come on. It came back on today for a lil bit
Old Mar 19, 2005 | 11:15 PM
Nismotic's Avatar
Always sunny in philly
brake fluid is low. when your brake pad is low, you'll hear a dull screeching sound coming from your brakes. There is no sensor telling you your brake pad is low. refill your brake fluid and you'll be good to go
Old Mar 20, 2005 | 03:13 AM
nosispower's Avatar
When your alternator's worn, the low voltage will cause your instrument panel to get screwy and random lights will start coming on. When I first bought my car, the brake and battery lights were on and the dealer replaced the alternator for me. Lights went away.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
