ks
Old Mar 10, 2005 | 02:41 PM
maximaintheface's Avatar
ks
i just replaced mine. havent took the car out yet im waiting til i have to leave. but should i notice differnce right away or will it take a while ive seen so many mixed awnsers form pepole and i just want to know the truth. my harness seems wrong. but im not sure. is there supost to be 2 wires coming into the harness and only 1 coming out?
Old Mar 10, 2005 | 02:43 PM
o and i found if u put a little duct tape on a coat hanger and use it to hold the ks it works really good. i just held it then doped in the bolt with a magnet and used the hanger with duct tape to hold it in place while i treaded the bolt it then just removed the duct tape by pulling up on the hanger. i dunno it worked for me took me about 15 minetes to replace it , this was my first time ever doing it and it was easy and i have no blood on my hands so ya. it was pretty good
Old Mar 10, 2005 | 02:58 PM
MDeezy's Avatar
I've never had a bad KS (knock on wood) but not sure if you would feel the power right away but you should see it when you notice your getting better gas milage. I'm not sure about the wires but I know it should have one comming out connecting to the KS.
Yea changing the KS was easy for me too, changed on my brothers Max, once I got a 12" extension and universal joint it tool 3 minutes to change.I even managed to fit my big ass hands in there to start the bolt then finish with the ratcher.
Old Mar 11, 2005 | 04:44 PM
hmm any 1 else?
Old Mar 11, 2005 | 04:54 PM
BigLou93SE's Avatar
reset your ecu just to be sure
Old Mar 11, 2005 | 08:45 PM
already did. it seems to be the same. mabye a bad connection or didnt tighten enough i dunno ill check it out later
Old Mar 11, 2005 | 10:21 PM
Zeus97MAX's Avatar
I just replaced my knock sensor this week, and from what I have read, the benefits should be felt over a period of time. I have noticed that the acceleration is better, but nothing drastic. I used a 10" extension with a swivel joint, and had the whole thing done in about 20 mins. I didn't get a bloody stump, but I definitely had some scratches and nicks to remind me of the ks for a few days.
Old Mar 11, 2005 | 10:37 PM
LowProfile's Avatar
It'll take time for your engine to map out the new settings..maybe couple of days.
Old Mar 11, 2005 | 11:35 PM
sweet cause i was liek damnit this sucks im not noticing anything really
Old Mar 12, 2005 | 02:17 AM
dayglo's Avatar
i read this too
"After a few days of driving, the car pulled a quite a bit harder. It now has more power in the lower RPM range (<3,000) Is this possible?
Yes. When the ECU is first powered on, it tests all sensors. When the knock sensor would fail, then it uses a "safe table" which retards the ignition advance slightly. This prevents the engine from knocking, as the "safe table" has values for low octane gas.
When the ECU started up, and saw a good knock sensor, it took time to optimize the ignition advance. The ignition timing advances very slowly waiting for some slight knock. This is how the ECU figures out the octane you are running. HOWEVER, if knock is detected, the timing is retarded VERY, VERY fast. This reduces the incredible stress of knock on your engine. This process repeats over and over."
here
iive never read anywhere what actualy happens when your engine knocks...its when the piston is slammed down at the wrong time on its compression stroke on its way up? i pulled a KS code the other day...im just not sure what a knock feels like. its been running a bit rough, are these tons of tiny knocks?? bad
Old Mar 12, 2005 | 02:22 AM
so how many miles do you think its gunna take?
Old Mar 12, 2005 | 08:27 AM
BigLou93SE's Avatar
I felt a noticable diff. under 3000rpm's like the motorvate.ca artice had said, it just depends on what your symptoms were with a bad ks. For me, my car hesitated badly under 3000, due to the choppy torque curve. If the actual ks was dead, and your harness was fine, you will eventually get the effects of the new ks. Check to see if it's tight enough, also.
Old Mar 12, 2005 | 11:52 AM
i dont know how tight its supost to be and i cant torque it right because first of all i cant find my tourwe wrench plust with the swivel at that angle its not going to tell u the actual rating
Old Mar 12, 2005 | 12:12 PM
MaximA VlaD's Avatar
to allow your ECU to map out the new ignition timing using info from your new KS you need to give it a week or two of normal, everyday driving. everytime you put stress (by hard acceleration) on your engine, the ignition advancing/retarding done by ECU will be paused. It only tests different ignition timing when you are driving at a constant RPM and speed setting. Like on a hwy using Cruise Control.
KS is a piezoelectric element that creates AC current when it detects a "knock," literally. the harness is right, two wires in, one out. the base of the KS is the ground. don't overtighten it.
you will not be able to just NOTICE the difference. it is not like ur putting a SC in your car. after driving normally for a week or two your ECU should have detected the optimum setting and your gas mileage plus original power should be restored. be sure to follow the manufacturers recommendation and use 91 or better octane rated fuel.
Old Mar 12, 2005 | 12:17 PM
Chickan's Avatar
Engine "knock" is when the fuel burns prematurely, before it enters into the chamber and spark is applied. If audible it is generally considered pretty bad, and sounds like "ping ping ping ping ping ping", more than how you would think of a "knock." Running rough can be contributed to a KS I suppose, but you are probably better off checking fuel filter, spark plugs, other maint. items first. If you don't get a KS ecu code (or ghost code), then you are probably fine ...
Old Mar 12, 2005 | 12:32 PM
AKA pre-ignition in our piloty talk.
Old Mar 12, 2005 | 12:54 PM
ya i know what the sensor does. i have since i started posting. i was just wondering how long it will take the ecu to get ready lol. thanks though but i already know what it does.
Old Mar 13, 2005 | 12:29 AM
whats the longest its gunna take . i just want to know if i need to tighten it more or what, nbut i dont want to if its fine cause tehre is no point and it might crack or somthin else
Old Mar 13, 2005 | 12:36 AM
yeah, if you tightened it fine, leave it and give it some time. drive like a grandma.
Old Mar 13, 2005 | 12:43 AM
i have been i hate staying like under 3500 . i just want to floor it but then im like wait... dont do that cause you will die and ****. o well i just cant wait to be like vroom and take off from a light and not be all gay and slow like it was with the bad knock sensor. its pretty stupid when you barley beat a civic off the line lol. my car lags so bad under 3000 after 3000 its pretty quick. but from a dead stop its rediculous
Old Mar 13, 2005 | 09:50 PM
ok this is kinda pissing me off. ive drivin like 100 miles or so and no differance. i took off and it seems the same. would the code come back on by now if its not tight enough or w.e
Old Mar 13, 2005 | 11:27 PM
anyone ? i guees i culd check without reseting my ecu
Old Mar 14, 2005 | 06:37 AM
knight71's Avatar
Yes it would come back on, if theres is still a problem...maybe you need to retourque it..thats what I had to do..Also. I changed my KS harness.
Old Mar 14, 2005 | 11:09 AM
no code has shown up yet. so im guessing that its fun just adjusting?
Old Mar 14, 2005 | 11:10 AM
fine* .
Old Mar 14, 2005 | 06:00 PM
im thinking mabye its taking longer cause i just started using 91 octane wich is the higest i can get. and the gas i had in before was 89 so mabye it was mixed i dunno
Old Mar 14, 2005 | 09:42 PM
finaly noticing somthing not as dramatic as i thought it would be but stll better then when i got a y pipe
Old Mar 14, 2005 | 11:45 PM
just took the car out again and i have to say im impressed i had a passanger and we went on the highway and it seemed like nothing to go form 20 to 70 before it would lag more
Old Mar 14, 2005 | 11:52 PM
i would still stick to grandma driving style... until i have all the toys and sitting in a line at the track..
Old Mar 15, 2005 | 12:17 AM
all the toys?
Old Mar 15, 2005 | 08:39 AM
fms, sc, pulleys, valves, chip, intake, brakes, adj tranny..
i am just saying, in my case it is not worth driving like i used to (the way you like driving) because i got in trouble for it. hope you dont, it's a pain in the a$$. i would rather go to the track and test the performance of my vehicle and have fun while doing it
Old Mar 15, 2005 | 10:16 AM
lol i dont drive like that i was testing it out... i rarley speed im not some 16 year old kid ive been driving for a while and gotten my fair share of tickets.
Old Mar 15, 2005 | 11:14 AM
ditto.....................
Old Mar 15, 2005 | 11:21 AM
lol i guess thats how you learn
Old Apr 1, 2005 | 04:31 PM
98 GLE's Avatar
I had the (and still have) the same problem you seem to have had. I replaced my knock sensor, expected dramatic results, and then tightened it then coded it then tightened it then left it and on and on. It has now been about 1 1/2 weeks and I am starting to notice a small gain but still serious lag off of the line. I normally power brake to around 1500 RPM's (automatic (DAMN!!!)) and it takes me longer to get from 0-25 than to get from 30-60. It is reasurring to know that it took a long time for yours to finish mapping.
