Getting this bastards pulled off...
Old Mar 12, 2005 | 03:26 AM
renatonetmail
Anyone has any tips or tricks to pull the Corner lights out?
Got the screw from the top out. And try with a flat screwdriver from the hadlamp side to get it out but none of the two corners want to come out. I am exaclty doing what it says in the owners manual.
HELP... i dont want to go "beast" and possibly brake them.
Thanks in advance.
Old Mar 12, 2005 | 03:29 AM
jackiss2888's Avatar
I noticed that for me, it wasn't a matter of strategically doing it, but rather just finding the right place they would slide out.
If this is the first timethey are comig out, it may be a hassle, just don't break anything.
Old Mar 12, 2005 | 06:19 AM
njmaxseltd's Avatar
You need to get a tall flat blade screw driver down just onto the lower ball joint and pry that sucker apart. If you pull the top out slightly and look down, you'll see the joint thats holding the light onto the fender. Slip your blade just between that joint and twist it. That should pop it out. Put a dab of grease on that joint so the light releases really easy next time you need to take it out.
HerpDerp1919
Sep 29, 2015 02:02 PM
Sep 27, 2015 08:37 AM
