Headlight question
Old Mar 13, 2005 | 04:51 PM
MaX_sHIfT_iMa's Avatar
Headlight question
i was looking at my headlights today and i noticed that qhite a bit of condensation is built up in the drivers side headlight. Is that normal? Is it possible to take the headlight apart to dry it out?
Old Mar 13, 2005 | 04:52 PM
tbombs32's Avatar
i think a hair dryer will dry it up
Old Mar 13, 2005 | 04:57 PM
gto400no1's Avatar
i dont know that i would say its normal, i have never had a problem but i guess it probably happens to some people. yes u can take it apart. to take it appart u have to remove it from the car, take the clips off, heat the oven to about 250, TURN OFF oven, then place them in for about 10 min and u should be able to pry them appart. i think thats the temp and time i used when i did my retrofit.
Old Mar 13, 2005 | 05:05 PM
so after i heat it up and pry it apart and clean it up... just clip it bak together?
Old Mar 13, 2005 | 05:09 PM
gto400no1's Avatar
then put it back in the oven for the same temp and time.
Old Mar 15, 2005 | 06:32 AM
HomerMAC's Avatar
Donating i30 Owner
u really dont need to open it up.. jsut make shure the lettle breather type holes on teh outer part of the headlight and the inner part arnt clogged.. just stick lik ea paperclip in there to make shure its open then just keep ur headlights on while driving even during daytime for a while.... then ull be fine..
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
