Brembo Cross-drilled/slotted Brake Rotors
Old Mar 13, 2005 | 08:22 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
BREMBO CROSS-DRILLED/SLOTTED BRAKE ROTORS
Does anyone have these on their car? Simply I need some feed backs. I need to know if they are very noisy, and what type of pads you are using, and did yours get any crack into it.
Thanks In advance.
Old Mar 13, 2005 | 09:10 PM
VIP Maxima
i got brembo x drilled/slotted matched with raybesto pads and its been nothing but a pain in the a$$. grinding noise.
Old Mar 13, 2005 | 09:28 PM
CystumMax's Avatar
I heard pretty bad things about Raybesto Pads, I have them for rear breaks and they make hell of a noise.
Old Mar 13, 2005 | 09:58 PM
matty's Avatar
Ive had Raybestoes on my fronts with nissan blanks factory rotors for over 2 years and they have never made a noise once ever. Match them up with any other rotor and I have heard bad things about them
Im about to install all Brembo slotted rotors and Axxis Ultimates when the weather brakes..
-matt
Old Mar 13, 2005 | 10:09 PM
MaxGordon7's Avatar
if you have slotted rotors your going to need good pads other wise they will get destory fast.
Old Mar 13, 2005 | 10:36 PM
MaximaTodd's Avatar
G
i have those rotors with oem pads, no noises and no premature wear. fantastic combo.
Old Mar 16, 2005 | 12:24 PM
wespac187's Avatar
Brembo-raybesto
Got brembo drilled/slotted rotors all around with raybesto pads. Performance is much improved from factory rotors and pads. Raybesto pads are the best pads when it comes to not leaving brake dust on your rims either. Got a par of brembo rotors cheap on ebay. The brake pads cost me like 40 bucks a set also.
I would recommend the two...anyday
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
