universal 02 question
Old Mar 15, 2005 | 01:13 PM
C MAX's Avatar
i have the front 02 sensor, and would like to know what to do with the two white wires. there are a total of three, one black and two white, are both the white wires the same or do i have to figure out which one is which.
Old Mar 15, 2005 | 01:54 PM
jbreit's Avatar
One of the wires is the actual signal wire. The other two wires are for the heater element in the sensor itself...it keeps it cleaner and extends it life. I can't tell you which wire is for signal. I would assume you should be able to measure some kind of resistance between the two heater wires and then resistance between the signal wires and metal case of the sensor....??....
Buying universal is a lot of screwing around when you can get a bosch replacement with an OEM connector on it for $60 from oxygensensors.com.
Good luck
Old Mar 16, 2005 | 03:43 AM
C MAX's Avatar
Good luck
thanks. well i hooked it up exactly the way it came off the old one and so far so good. no codes yet, i have the bosch but not with oem and i paid 55 bucks.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
