Knock Sensor ????
Old Mar 16, 2005 | 04:14 PM
krue92's Avatar
Knock Sensor ????
I was driving my car home today and I the check engine light came on. I checked it when I got home and it was pointing to the 5th cylinder misfire. I checked the resistance on the fuel injector and it was fine. I unplugged the coil back while it was running and it started running worse, so I know it was doing the job. So I cleared the code and started it. Then I got the knock sensor code. I checked for continuity on that and it didn't have one. I was wondering how to tell if it really is the knock sensor causing the problem. How will the engine run? Any thoughts would be great. Thanx.
Old Mar 16, 2005 | 04:15 PM
NmexMAX's Avatar
dot dot dot ...
Read the stickys, and if in the end of reading and education yourself, you find that you do in fact need a KS, let me know, I have an extra one for sale.
Old Mar 16, 2005 | 06:51 PM
krue92's Avatar
I read them, and I think I am measuring everything correctly. I mean how will the car run with a bad one?
Old Mar 16, 2005 | 07:18 PM
krue92's Avatar
Its throwing two codes. The 0304 knock sensor code and the 0201. What should I look for on that code.
Old Mar 16, 2005 | 07:58 PM
fadeaway's Avatar
Go Hokies!!
I'm running on a bad knock for now.. it's really not an absolute must to replace it right away.. definitely everyday driveable with a bad knock. Once I replace it I'll probably find out really how it was affecting my driving experience.. but until I set aside some cash to buy one, I'm fine.. (at least I think).
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
