coolant thermostat / temp of lower rad hose
Old Mar 17, 2005 | 08:47 AM
vstrt's Avatar
My upper radiator hose gets hot. However, my lower radiator hose remains COOL. My fans run constantly, but the guage inside the car stays right in the center (doesn't ever show any signs of overheating). My heater works find. Also, I just recently replaced my coolant thermostat with one I purchased from Autozone.
Does anyone know what temp the lower radiator hose is supposed to be? cold or hot?
Old Mar 17, 2005 | 09:12 AM
maxgtr2000's Avatar
KH3 by popular demand
When's the last time you did a radiator flush, this might help.
Old Mar 17, 2005 | 10:38 AM
Broaner's Avatar
2060lbs and falling...
I've never thought about that but it would make sense that the lower hose is cooler. That is the direction of flow afterall.
Old Mar 17, 2005 | 10:45 AM
vstrt's Avatar
I did the flush when I changed my thermostat.
The reason I'm concerned is because my fans are always blowing and my lower rad hose is a lot cooler than the top one (which is really hot).
Old Mar 17, 2005 | 12:20 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
i think all that means is that you're radiator is doing its job
Old Mar 17, 2005 | 05:10 PM
Broaner's Avatar
That or the fan relay could be messed so the fans are always on. What is your coolant at usually?
Old Mar 18, 2005 | 10:37 AM
vstrt's Avatar
How do you fix the fan relay?
Old Mar 18, 2005 | 02:48 PM
Broaner's Avatar
Pull it out. Go to dealer. Buy new one. Put new one in. I would open it up first though to see if anything looks out of whack.
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
aminus21
Sep 12, 2015 04:53 PM
