Brakes!
Old Mar 21, 2005 | 07:25 PM
maxima_kenny96's Avatar
Brakes!
DO nissan Caliper pistons twist in instead of just come straight out?
Old Mar 21, 2005 | 07:26 PM
jhay's Avatar
The rears twist in. The fronts push in
Old Mar 21, 2005 | 07:32 PM
aznprid972's Avatar
i believe you can just push it in. i know on the newer cars, you would have to twist it while you push in and it is a pain to do w/o the special tool. i took my caliper off one day while changing the studs on my front wheel and the brake squeezed up. to open them back up, i used a c-clamp to compress it back in. (dont forget to open up the brake fluid container under the hood too so the pressure can escape that way.)
oop.. he beated me to it.
Old Mar 21, 2005 | 07:34 PM
ok thanx
I was wondering, what is the special tool needed cause using a c-clamp and pliers was a pain.
Old Mar 21, 2005 | 07:46 PM
Maximus_95's Avatar
c-clamp is not a pain man! its like the easiest thing to do.
Old Mar 21, 2005 | 08:06 PM
MaxCanesFan's Avatar
There is a tool looks like a small box that has alot of different faces on it that you can use to turn the rear pistons back in.
The front there is another tool that pushes against the metal backing that acts as a seat for the brakes and compresses the piston (similar to a c-clamp but made for the brakes). If you got a NAPA or other auto shop you can actually rent the tools, but if you buy them its only like 5 or 6 dollars. Saves a whole lot of time and beats the pliers method.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
