tokico illumina's and h&r springs..... any alignment issues??
Old Mar 22, 2005 | 12:46 PM
$EXY BLAXIMA's Avatar
Hello, just received my Illuminas and H&R springs recently ( can't wait to have em' installed, as i have been hearing lovely things about this combo) and I was wondering if i would would have any problems getting a proper wheeling alignment as i hear when your car is lowered it is nearly impossible to get your car back to factory specs? is this true and if so how can i get a proper alignment done? because i know how much a PITA it is to drive a car with a bad wheeling alignment as i have done this in the past when i had those POS dropzone springs!!
Old Mar 22, 2005 | 02:28 PM
Stuntin' 101's Avatar
no you shouldnt have any real problems. the only thing you might have to get is a camber kit. more than likely you wont, cause it is only a mild drop. there are many people in here that get to factory specs without any issues, some need the camber kit. i have h&r's, and i have one wheel the lines up fine, and need a camber kit for the other one. the camber kit's are only about $30. its just a special bolt, not a real big expense even if you do need it..
Old Mar 22, 2005 | 02:33 PM
PLUMMAXSE's Avatar
You shouldn't need a camber kit, because the H&R's don't lower the max enough to require it. Just get an alignment and you'll be good to go!!
Old Mar 22, 2005 | 04:34 PM
zazon's Avatar
just installed illuminas and tokico springs, pretty much the same drop as H&R's, and we were able to get it to spec easilly
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
