Removing E_brake Please Help!!
Old Mar 22, 2005 | 03:14 PM
andre66951's Avatar
Can anybody tell me how to remove my e-brake. I have taken out the center console and removed the boot allready but I dont know how to take off the e-brake handle. I looked in the how to's but it only tells you how to remove the boots and the shift ****.
Old Mar 22, 2005 | 04:13 PM
A32Matt's Avatar
what are you replacing? if it's just the cables, then you didn't need to remove any of that. i watched the tech put cables on my car and everything was done from underneath the car.
Old Mar 22, 2005 | 04:18 PM
1MAX2NV's Avatar
Are you talking about the plastic cover part or the whole thing including the metal part?
Old Mar 22, 2005 | 04:57 PM
andre66951's Avatar
Just the plastic cover part, I want to take it off without breaking it because I might still need it.
Old Mar 22, 2005 | 05:00 PM
99se5spd's Avatar
sit your seat up straight, plant your feet on the floor behind the pedals, grab it with both hands and push towards the radio....hard, you may want to stick a small pillow in front of the radio so when it does come off you dont put it into the dash.
Old Mar 22, 2005 | 05:14 PM
gyallist's Avatar
Is it really that easy?
Old Mar 22, 2005 | 05:27 PM
gyallist's Avatar
are there any tools that would make it easier to remove the handle
Old Mar 22, 2005 | 05:30 PM
ManualMaxima's Avatar
5th Gen till she dies!
a hair dryer or heat gun might make it easier.....heat the handle up so the glue under it kinda melt and looses alittle grip. alos try putting a flat head between the metal part and the back of the e-breake and easily pry it off.
Old Mar 23, 2005 | 07:46 AM
1MAX2NV's Avatar
A hammer and a punch. Put the ebrake down. Place the punch on the back end of the ebrake handle. Hit the punch with the hammer and drive the ebrake cover towards the front of the car. If you don't have a punch, a block of wood will work too.
Old Mar 23, 2005 | 12:52 PM
tslrock514's Avatar
yeah give it a good yank :-p
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
