Replacing Dash clock help needed
Old Mar 23, 2005 | 12:54 PM
cefiro_max99
replacing my dash clock, how to take off air vent and emergency part off?
Old Mar 23, 2005 | 12:56 PM
tslrock514's Avatar
stick a screwdriver in there and pry. it didn't go very high up for me but i wasn't going for the clock i was just trying to take center console off for the first time and i didn't know where to get started LoL. but yeah go easy on it it can be a pain in the *** to get back on
Old Mar 23, 2005 | 01:06 PM
cefiro_max99
damn. i dont wanna end up buying new vents. how about the emergency single part?
any one know if they sell the clear part for dash clocks? mines looks dirty.
Old Mar 29, 2005 | 04:27 AM
mkothari's Avatar
I have similar problem my clock keeps going off and on. I tried to take off vent by prying flat screwdriver around it but it did not work at top but bottom came loose. (In the process I broke one of the vent ... be careful). I have not been able to take it off completely. If you find out trick to it, please let me know.
mkothari
Old Mar 29, 2005 | 05:42 AM
AllMaxxedOut's Avatar
Just have to use a screwdriver w/ a wash cloth and pry from the climate control console. I actually used my hands but could be too much if you pull too hard. I thought that I was going to break it the first time but then I just said if I do ohh well. But it won't. You'll hear a pop when you get them out of the two holes on each side. Then you can slide out the entire piece w/ vents. To get the clock out, just let the entire piece hang and get a phillips screwdriver to remove the two back screws. I disconnected the hazard & defroster plugs to make it a little easier.
larryseibel's Avatar
its just held in w/ clips. just be careful
Old Mar 29, 2005 | 07:43 PM
MystA RavE's Avatar
I have the same problem..i just took it off to tape the plug in the back but it didnt seem to fix the problem! As for removing it...it took me about 20 min to figure out. Start at the lower right side..then lower left side...and finish it off by pryiing it along the top. Dont be afraid to use force...its a very strong piece. It feels like youre going to break it but itll be fine.
smplyamzng
Dec 13, 2015 01:19 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
TonyJr
Aug 20, 2015 12:14 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
kirkhilles
Aug 8, 2015 10:53 AM
