only passenger side bumper lights don't work...
recently changed my bulbs and my bumper lights from the cheap ebay clears to the diamond clears from CM....anyway, changed my turning light bulb there as well so it lit up a legal amber (it's the new ones from sylvania that look blue/clear when off but light up amber) anyway, everything was fine before I did this and now, those bulbs won't light up at all only on that side....I checked every fuse....they are all fine...additionally, when I put my right blinker on, it flashes extremely fast in the rear and in cabin...which I now is a feature to tell you there is something wrong with the front or vice versa....and of course my multimeter is busted the one time I need it to test some wiring...
my conclusion is, it can't be both sockets because both the turn signal and side marker both don't work (odds of both going bad at the same time is crazy and the bulbs are fine I have tried them in other sockets)....I didn't touch any wiring during the install so this is disturbing...the right rear blinker works fine however (just blinks extremely fast unless I put the hazards on, then the rear blinks normal, the front one still doens't work though)....also opening up the factory wire loom there shows that the wires from the signal and side marker never connect together for obvious reasons....so I can't see how all four wires to both of them have gone bad unless they meet up somewhere else eventually...are there any fuses I am missing...?
03VQMAX
Dec 7, 2015 04:59 PM
KGMtech
Aug 18, 2015 09:21 AM
jchronis2552
Aug 13, 2015 07:48 AM
