Suspension help
Old Mar 26, 2005 | 09:36 AM
boosted95's Avatar
Suspension help
anyone in New jersey know how to remove suspension from one max and install it one another?? i need someone to help me out bc im swaping with a max that is immobile. let me know
shady9599@aol.com
AIM - shady9599
Old Mar 26, 2005 | 12:52 PM
ThisMaxIsTight's Avatar
get a haynes manual bro and some good tools...what kind of suspension components are you installing?
Old Mar 26, 2005 | 01:13 PM
njmaxseltd's Avatar
Jack the car up, both L&R sides must be up in the air to complete the job. You can do the front and rear seperately.
Rear:
Remove the 2 12mm nuts the hold the upper shock mount to the body. Look in the trunk behind the inner corner trunk liniing next to the seat back. Next remove the 17mm bolt on the bottom that holds the shock assembly onto the beam.
Fronts:
Remove the brake line clips & ABS sensor wire 10mm bolt(if equipped).
Remove the 2 19mm nuts from the lower strut mounting flange. Hold the bolt with a 17mm box wrench while you spin the nuts off, then remove the bolts.
Remove the 3 14mm (95-98) 22mm (1999) nuts from the upper strut mounts.
Old Mar 26, 2005 | 03:37 PM
boosted95's Avatar
i need to take off shocks and springs ( aftermarket ) and take off shocks and springs ( stock) and then switch them to the other vehicle
Old Mar 26, 2005 | 04:15 PM
2 Da Max's Avatar
Rear:
Fronts:
lol its actually alot harder in real life
Old Mar 26, 2005 | 04:50 PM
njmaxseltd's Avatar
Naaaa it's cake work.
Old Mar 26, 2005 | 04:52 PM
CaLSoNiC
Go buy a haynes manual. The best $8 you will ever spend for your car.
Old Mar 26, 2005 | 04:58 PM
zazon's Avatar
i disagree, i did my first suspension install myself, i threw the tokico illumina kit on, and while it took me a little while longer, it wasnt very hard at all.
you need a torque wrench, 22, 19, 17, 12mm sockets/deeps, 17,19mm open end wrenches, spring compressors (7 bucks at harbor freight), and 3 hours. there are good writeups in the FAQ's that have some helpful tips.
good luck!
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
