300zx BBK question
Old Mar 26, 2005 | 05:02 PM
Maximus_95's Avatar
300zx BBK question
i have read that you have to mill down 3mm on the rotors to make this possible. The thing is, it is said to mill down 3mm on the radius of the rotor? is that right? or do they mean mill down 3mm thickness wise of the rotor? please get back to me asap. thanx guys.
Old Mar 26, 2005 | 08:17 PM
Aaron's Avatar
Langley AFB Sux
3+ mm of the radius....not the thickness. When I did mine I just turned down the edge and kept test fitting them. Not too hard.
Old Mar 27, 2005 | 12:33 AM
Maximus_95's Avatar
you know what, that is so weird, because when i got the rotors, they were like the same size as my stock rotors, so why do you have to mill down the radius?
weird thing is that when i got the rotors, i thought that they were already milled down, so i just put them on anyways, and after i was done with everything, it seemed like the brake pads were totally pressed against the rotor, like someone was pushing on the brake pedal, so i thought it was the thickness that i had to mill down 3mm.
Can you explain to me how making the radius smaller will make them fit?
i just want to make sure and understand exactly, before i get them milled down. thanx.
Old Mar 27, 2005 | 01:41 PM
MrDicks95SE's Avatar
Offset Is Everything.
bump im just as confused...
Old Mar 27, 2005 | 03:35 PM
Maximus_95's Avatar
so, which way should the rotor be mounted? slant forward, or slant backewards. in other words / or \
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
