Transmission Question
Hi. My 97 Maxima is making a buzzing or humming noise (the kind of noise you hear when power steering fluid is low) when its cold. I checked steering components and it wasn't them. I can hear the noise clearly when I'm sitting inside the car so I started it this morning and got under it to see where the hell it was coming out from. I suspected some tranny component so I took to a mechanic and he said that it might be the tranny's torque converter and sent me to a transmission specialist to diagnose it. I described the noise to the Transmission shop guy and he said it's most likely to be the transmission pump going bad and it's $555 to replace it. Have you guys had any similar problems before with same symptoms?? any input will be greatly appreciated>
I haven't had any tranny problems myself yet <knocks on wood> and I can't hear the noise you are talking about (obviously) but it sounds fishy to me. I don't trust shops much. Transmission pump? are you auto or manual?
yeah, i had the same problem, was there for a year, untill i got really frustated and flushed all the pipes;water, engine, tranny, steering pumps, everything. filled them up again and its not heard since 8months now...
(also i remember, i checked tranny oil every saturday, it was leaking from somewhere i had to fill up like a 1/4ltr per week. finally saw it leaking from the pipe that goes from the radiator to the tranny, had a small cut.)
and as far as i know(i had an audi s8 with oilpump problem) if the oil pump goes bad, it'll screw up the converter and that'll cost ALOT! rather get a new tranny!
anyways,
best of luck..
anyways,
best of luck..
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
