Removing Side Marker Light Bulb
I wanted to know how to remove the side marker light. Not the turning signal or parking light, I am talking about the one that lights up when you put your signal on. Only on 95-96 model. Does anyone know how to change the bulb?
Ok, first you say it's not the turning signal light but then say it's the one that lights up when you put your signal on? Huh?
When I changed to clears on my 99 I just stuck a flathead screwdriver between them and popped out the smaller housing. After that it's SOP.
Don't know if that'll help.
Owner manual its basically self explanatory.... knock yourself out.
http://www.courtesyparts.com/nissan-manual/index.html
Originally Posted by max_speed97
I think he means the one next to the headlight
If you have a couple of elbows you can change it w/out removing the housing itself. If not, just take out the one screw the holds it to the headlight then use a long flathead screwdriver to pop out the stud that presses into the body. Use a flashlight to make sure you're right on the stud, or just pull the thing out but it might break if you do it that way so be careful!
vingodine
45
May 21, 2016 12:46 PM
98nismomax
Aug 13, 2015 12:44 PM
